Hey All!
I've browsed through the many overheating threads, and I haven't seen this discussed (forgive me if I've missed anything).
My 77 FJ40 (2F motor, 77k miles) likes to overheat when I start driving it in the spring/summer. It stays garaged in the winter. The magical key seems to be the "Warm Pull" knob on the dashboard. I found that if I keep that pulled out, that my engine runs nice and cool. Pulling that knob essentially causes my backseat heater radiator to steam.
My problem now though is that the knob doesn't seem to have the same effect it used to. There is some warmth coming from backseat heater, but not as much as normal, and the temp gauge gets hot before the backseat heater gets very warm. I would be worried that I've got a clog in my lines back to the backseat heater, except for the fact that it's actually leaking a little coolant.
My reason for posting is to see if anyone has been through this type of thing, and can offer any suggestions based on experience. My 40 spent some time in the shop and they couldn't find any issue but it was on that drive that I discovered the warm pull switch fix. Not looking for a diagnosis, but I'm hoping to get steered in the right direction before I go replacing things like radiators. I've seen a common theme among threads where people replace a lot of things and the problems remain.
My radiator overflow is topped off, but perhaps I should do a radiator flush or try to have the coolant system back to the backseat heater serviced.
Thanks so much!
Thanks so much!
