its not mean air coolantNot air, coolant.
ok, thanks, thats what i thought. Ill get a new reservoir cap as mine is super dried up and fits as loose as the washer bottle cap lol.I'm pretty sure it should flow freely. Clogged or kinked
well i really like that last sentence hahahhaIts a hundred degrees out, your engine is going to run hotter especially working harder pulling a grade that it does when its 75 out.
Maybe your thermoset is starting to go bad. Perhaps the little bleed by port is plugged.
Check your radiator fins and make sure air can get threw - spray water threw from the engine side and wash out the trash that can block the air flow
If its not boiling over then its working.
holly jeez, your thorough documentation never ceases to amaze me. just read through it at work, and will go through it again with the car later today. I keep forgetting that the rad can look full when its not, so hoping that that is the simple fix, otherwise im hoping its just he thermostat that needs replacing. The initial spike to halfway at cold start feels like a sticky thermostat not opening when its sposed to. and maybe getting stuck open more then its sposed to, and when not a crazy hot hill day it stays in the normal cool zone, but inst open enough when it needs it. fingers crossed. always, thanks for your sage like help @duncanrmTickling the red line is not acceptable in my view.. that's likely over 100degC.
Here's my checklist for an overheating 2H.. pay particular attention to the comments on the viscous fan hub. My own 60 series 2H will climb a big hill on a 41deg day with the A/C on and still only be at the 2/3rd mark at the top (95deg). It'll come down from there fairly quickly once the hill climb is done.
Overheating 2H
docs.google.com
shes definitely OEMDefinitely use an OEM thermostat only.
The 2H coolant fill is generally not problematic, covered off in that guide. Wild swings in temperature is often a sign of low coolant. Doesnt sound like yours to be honest.
I do see a quick uptick in the coolant temperature when the thermostat first fully opens - then it comes down.. I dont think this is visible on my factory gauge - I really only watch the digital Engine Guard display and I'm only talking an uptick from 67 -> 77 and then it generally resettles at its happy point of about 74deg.
If you dont have an Aisin Hub fitted you definitely need to swap it out. Dont assume that your hub is working well even if it is Aisin, if its old I'd replace it (understanding that its not cheap though!). I am yet to come across a reliable test that confirms a hub is working well.
That there was a good vote!I vote for change the thermostat.
