Poser said:
Yes Brett, please elaborate on this.
Thanks!
This is from the Marlin board. The gears in the Orion have the non taper mentioned in this post. Poser brought up the point, that if this was the case, all the cases would be popping into neutral. At first, I figured that was true. Now, I am starting to believe this is the real problem. The little things we have all done have helped but have not fixed the problem. If anyone on this board knows Marlin, give him a call and find out from the source if all of his first generation gearsets had a neutral problem.
http://board.marlincrawler.com/index.php?topic=2436.msg19917#msg19917
Quote:
"The problem with your transfercase is internal. The 4.70:1 gear set that you purchased through Advanced Adapters is using our old discontinued 4.70:1 gear set made by their gear cutter. I know this because he was our gear cutter for about 3 years and as soon as we left him to make better gears, A/A immediately began retailing 4.70:1 gear sets (both A/A and Marlin used the same gear cutter). The problem is that his machinery lacks the ability to cut those old gear sets (originally designed in 1997) the way the manufacture Toyota did -- And this is one of the reasons why we left him.
Our new 4.70:1 Gear Sets are cut by none other then Toyota©'s Gear Cutter in Japan. We went straight to the source and our New Gears are manufactured by the same company that made the gears in everyone's pickup on this board.
The above picture is a shot of the shift hub teeth on the Input gear. The factory 2.28:1 gear sets used a 2° taper that was tapered into the gear - forcing the shift hub to stay in place. Our old discontinued gear sets (now A/A's) does not have this 2° taper and therefore the shift hub can "float" up or down those teeth depending on coast, drive, and load.
This was a HUGE problem with our gears when we used to sale those. Customers all over the place would complain about it popping out of gear, it would even happen to Marlin. So to counter this problem, the only thing we could do was try to strengthen the detent ball spring pressure and hope that the fork could keep the shift hub in place, but we found that this was only a 50/50 chance of working. Some units would stay in gear while others would still pop out. It may have been due to some shift hubs with higher mileage that had wear on them but we were unsure.
So we demanded for our gears to have the same 2° taper as the factory gears but our old gear cutter lacked the ability to cut any taper to those teeth. So we were left with no choice but to leave him and find a better gear cutter and that's when we hired Toyota's gear cutter. Now Marlin could design his gears the way he had wanted to..."
