Well crap, call me crazy… but that TOTALLY sounds like the gear backlash / lack of spacer issue Treeroot. I mean, if your stick is physically moving back and forth, it MUST be because the shift collar is being moved back and forth by the driven gear being thrusted back and forth. Hell, it would seem like the thrust washer would seriously help if not totally solve your problem then. If this was the case though, it would seem that ALL toy cases of this design, even factory, would have similar behavior w/ regard to the stick moving as you got on and off the gas (just less popping out because of the beveled dogs...). Is this the case?
Poser I got your PM and I appreciate the advice. I really just want something nice and reliable, but I tend to wheel with conservative technique, and I have heard of Dana 18’s holding up behind mild V-8’s too… so maybe one would be marginally acceptable. As long as it wasn’t too much of a “fusible link” in the drivetrain, I would totally run it. I’ve heard about combo-ing parts with a D20, but I don’t think this would do me any good for an offset rear output, would it? From what I found, there is no way to beef up an 18 with 20 parts and still have an offset rear output, since the 20 is a centered… or am I wrong? There is the 3.15 low kit from teramax for the 18, which would be OK for a roughly 60:1 crawl ratio… which wouldn’t be bad. I really just want something around 80:1 ish for sporadic slow, controlled crawling with lockers (not the primary use of the truck), but moreso for tractor like duties of moving trailers off road, pulling stumps and stuff… etc. I don’t need a sick low range, but I’d love something moderately lower than any stock setup.
If there’s just no way I can figure an offset rear case, there’s always the bail option of a beefy center output case. The propshaft should work fine, it will just be angled off to the side. The wheelbase is long enough that my gut feeling is that the angles won’t be too severe, especially with a CV. Vibration/ phase angles should have no problem… from that perspective its no different than a shaft running just fore and aft. I just love the look, the simplicity (maybe not, I guess), the extra protection of having both shafts tucked up on the passengers side. Its like many have said… just take rocks and stuff down the drivers side. I’ll go a long way to keep that Sals rear… I just like the offset too much.
