Official ONSC member buying/selling thread (24 Viewers)
Leatherman Wave. Selling mine since I bought the next gen wave+, date code is 1209, and it’s in great shape, always clean and oiled. $50 fittybucks
Swapping a H55 into my 1984 FJ60 and I need different driveshafts (shorter rear, longer front). Anyone have a set of driveshafts from a 85-87 truck they want to sell? I *think* they'll fit as is without me having to get custom lengths.
Do you know the measurements from the driveshafts that you need. 84-85 pickups and 86-94 pickups has different driveshafts as it went from solid axle to IFS.
I have both fronts and the rear, ifs and solid axle. Ifs is a DC and solid axle is a single joint. If it’s a solid axle driveshaft you can also use a FZJ80 front driveshaft for the the front. Get the measurements and give me a call and I’ll see what I have. I have a couple sets sitting around
Sounds good. I’ll work on measurements and text you.
@roflbox I’ll bring you a gasket for that can to CRR. I got a couple cans from @White Sheep last year and they held liquid just fine but they let out fumes kinda badly. Had to buy a multipack of gaskets but it solved the problem.
If you've got a bunch, I'll trade you an adult beverage for one at the RR.
Got a bunch of parts off of an 80 that i parted out and took the supercharger from and here's what's left, have a bunch more that's not listed but ask and i might have it, no axles, body parts, or interior panels. Got a lot of parts to list so if i miss something just ask about it, also all prices are OBO!!!! Some of these i understand i might be asking too much but hard to mark a price when some stuff is not listed for sale anywhere else. Will ship, PM on here or call at 919-869-4737
Pair valve tubes with valve, good condition. 130k miles. $250
Pair valve tubes for 1fz-fe supercharger 130k miles. $150
EGR valve with tube good condition with 130k miles. $175
Airbox silencer with tubes, fair condition. $50
1994 steering column and shaft with keys. $200
Battery box, good condition $30
Gas tank skid plate, fair condition, $50
Transmission crossmember, straight and good condition $75
1994 1fz-fe downpipe, cat, and crossover pipe with head shields under body, Great condition, $650
1994 1fz-fe upper and lower intake manifold with sensors, 130k miles, $300
knock off depo headlights, $50
1994 a/c- heat blower motor, good condition, $100
power steering cooler, $30
rear upper control arms, $50
alternator 130k miles with tensioner bracket, $80
1994 front axle abs harness no sensors, $60
white 1994 hood hinges, good condition. $100
radiator lower supports, good condition with bushings, $70
throttle cable with pedal, fair condition, $60
1994 steering wheel clamshell, not broken just tape to hold the bolts in, black, good condition $100
1994 drivers door harness, good condition, $80
Toyota spark plug wires from 2016, fairly used in good condition, $75
thermostat housing, hose and radiator metal pipe good condition, $100
airbox housing good condition $70
radiator shroud $50
Hood latch and catch, $50
1994 wiper motor $150
1994 1fzfe transmission and transfercase, just under 400k on the trans and pulls strong, found a brand new transmission for sale for a steal to put in my rig when i did the supercharger, transmission worked great when pulled, no issues with center diff and low range. $300
Interested in the the knock off depos as donors for a projector retrofit. Are you going to relic run? Also did this cruiser have steering column mounted cruise? If so I'd love the clam shell and cruise switch + harness.
I found one of the gaskets this morning and already packed it with the one for @roflbox . Now I'll just need to remember where I packed it in my jumbled mess of camping crap when we get to the site!
Anyone sitting on a set of 6 on 5.5 wheels in 17” flavor they aren’t using? Could trade cash or 80 series wheels (acorn style lugnuts)
I have some 16s
So, I have been informed that the time has come to get rid of “that truck in the driveway,” Old Blue, a 1977 fj40. To be fair, I bought the 40 almost a year ago with intentions of getting it running/drivable, swap some parts with my 79, and to tinker, most all of which did not get done. Life, work etc. got in the way of my plans. I thought I would put it out here first before craigslist etc. 1977 fj40 with a decent amount of the original bits on it (emissions). Running but not road worthy, at minimum brakes need attention and tires are cracked. I replaced the fuel tank with a CCOT one also the soft lines coming out of the tank. Title is a reconstructed title and unfortunately I do not know the history behind that. Previous owner had it since 2008. Asking $7,500.00 but will consider something reasonable. Let me know what questions you have and more pictures are available on request. PM is best. Thanks for taking the time to look.
PM sent
View attachment 2968781View attachment 2968782View attachment 2968783View attachment 2968784View attachment 2968785View attachment 2968786View attachment 2968787
LMK if that falls through.
