OEM rear view mirror mount adapter? (2 Viewers)
This works with our 100 series? Do we remove the brake light? Do we need to drill into our hatch?
I know lots of questions .. just unsure what else I need to purchase to run this. I agree -- this is a fabulous solution to what I was discussing.
So it suppose to go into this 3rd brake light location in the hatch that is a bolt in replacement.
My understanding to install is that it will bolt right up and the brake lights will need to be spliced in. The chase lights one would need to run power to. I have a switchpro that will control those lights. Will have to drop the headliner to run the wiring.
I havent had the time install everything and wire the camera up with the Naviks to use my factory screen.
The evil mfg camera has two RCA connectors and two separate power connectors for each camera. If the wolfbox mirror display has rca inputs and a 12v power out it should be plug and play.
I hardwired mine to my driver side fuse box (to the left of the pedal box)
Which fuses did you tap into for the accessory power and for constant power?
Edit: as a follow up on my own question, after probing with my multimeter, I chose the CIGAR (15A) for accessory power and the DEFOG (20A) as my constant power. Everything is working as it's supposed to. This is for a Wolfbox G930 rear view mirror/dash cam.
Im trying this off of aliexpress. It’s currently closed for CNY, so won’t receive it until the end of the month or first week of march.
I’ll report back. Already have it all wired up, although struggling with final camera location.
#129 looks like our deal.
OK, swore is saw how to get to #129......ebay listing a) stops at 125#, b) even if I go to ebay checkout (before I enter cc#), I don't see where to specify the number (129#).
If you scroll down to the product description on ebay you will see adapter #129. The pictures only show up to adapter #125. I think maybe there's a picture limit on ebay? IDK. It's weird.
This is what I did!
I received the bracket from ebay and I've had my Wolfbox 930 dashcam/rear view mirror camera installed for a couple weeks now. The #129 ebay bracket is definitely what you need along with the mirror adapter bracket from wolfbox. Everything is working well and the clarity of the rear view camera mirror is excellent (during the day). At night it's harder to make out details, but you can definitely see all headlights and street lights. Overall, this was an excellent upgrade over the OEM mirror with alot of added funationality.
does the the mirror adapter bracket come with each Wolfbox unit, or is it a seperate buy?
It's a separate buy.
You need three items in total (all separate buys)
1) The mirror itself
2) The mirror bracket (from Wolfbox in my case)
3) The mirror adapter (#129 from ebay)
#3 attaches to #2, which then attaches to #1.
got it. Just go frustratinly hung up on the ebay buy. didn't see where the seller msg was and hit bought. Now cancelled so I can do a clean reorder. Not an experienced ebayer:bang:
Definitely get the ebay #129 adapter ordered first. That item took 3.5 weeks to get delivered to me. Everything else I ordered from Amazon as their prices were a little cheaper than the Wolfbox website.
Below is my shopping list and I have approximately $180 plus tax invested so far. Most items bought through Amazon.
1) The mirror itself ( Wolfbox G930) - $100 / https://www.amazon.com/gp/product/B0BRLYT8M1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
2) Wolfbox mirror bracket - $20 / https://www.amazon.com/gp/product/B0B53FTB6L/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
3) The mirror adapter (#129 from ebay) - $20 / Special Bracket for Rearview Mirror Dash Cam 1234578910# | eBay - https://www.ebay.com/itm/388457977097?itmmeta=01K074DB9KPGQ72WTPKCFR891Z&hash=item5a71e65509:g:eek:hEAAOSwWHFjSDGe
Optional Items:
4) Wolfbox Hardwire kit - $20 / https://www.amazon.com/gp/product/B09X9F8GMT/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
5) Wolfbox License plate bracket - $20 / https://www.amazon.com/gp/product/B0B91ZTXTJ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I went to the Wolfbox website and didn't see a mirror bracket for the 100 series.
I see one for Tundra, 4Runner and other Toyotas.
Which bracket did you use?
Thanks.
Thanks.
The one I used is specfic for the G930 or T10P model mirror. They sell another one that fits more of the different models.
This is the one I used for the G930 mirror:
I did the same, just bought one that fits my particular mirror. It doesn't matter what vehicle it fits (per wolfbox) since you'll be using the #129 bracket. You just need the part that screws onto the back of your wolfbox mirror then attach #129 bracket to that.
See the 3rd picture in post #39 that shows the #129 bracket next to the bracket that came from Wolfbox. You throw that away and just use the rectangular thing that screws into the back of the mirror to attach the 129 bracket.
