OEM Headlight Assembly
Fargo
I am planning to order the headlamp assembly (81110-60P70) for my '73 FJ. I just wanted to confirm that this should work as a plug play with the provided harness that comes with?
Thanks,
Jerry
Not sure if it's still available - toyotapartsdeal.com shows it as discontinued.
Maybe:
Via @wngrog
''If you have closed light housings and the dopey wire bar on the fender, the plug and play kit is not plug and play. You will have to drill a big hole in your housings or put the relays upstream of all your factory stuff''
Maybe:
Via @wngrog
As long as you don’t have this type of light and fender junction is is plug and play.
if you have this type it is still doable you just need to do a few modifications
Thanks for the info. I called my local Toyota dealership and they were able to get one in for right around $50. It should be a great upgrade!
I priced local yesterday, they wanted $80! Told me it was Toyota MSRP.
Toyota OEM part number 81110-60P70: -> Click here <-
I paid $34.14 (33% off) and have this, and a $hit load of other Toyota OEM good stuff headed my way.
Thanks @Onur I'm out of the loop. Just ordered, to clarify do two bulbs come? my parts guy could not tell, but the above photo shows 2. Thanks, John
Yes. It’s a full kit
