I am restoring a 74 F motor FJ. I have seen pics of red and black. What's original?
Thanks!
I have one powder coated gloss black if someone needs it, and yes it was Safety ORANGE before that.
They were bright colored so as they took your hand off you would see it...![]()
Yes and yes. Also keeping the drum brakes.Did you read the link @landcrusher909 posted? Are you really going to bolt a failure-prone 45 year old fan back on your truck just because you can?
Matched the orange/red to flakes left in spots under that black. 3 coats with a touch of hardener.
A restoration always has choices along the way, I've found keeping in mind a final goal is important as choices are made along t he way. This one is going back to stock, as it rolled off the factory line with only the most minor of alterations: a better cam, a touch higher with bigger tires, and an electronic ignition. Fox shocks and lockers. Everything else down to the muffler is OEM.
@igotta40My Feb 1974 came with a plastic fan.
