Nuts and Bolts (2 Viewers)
I'm really interested in anything you guys have as I'm about to start down the restoration path after the Gilmer, Tx gathering.
I'll be glad to contribute to the list when we're done and thanks for your work making this list
Scott
I have searched hi and low for the best deal on nuts and bolts, and believe I found the place.
http://www.allensfasteners.com/
Check it out...
Here's an example for 10 pieces. $2.80 TOTAL. And shipping is cheap... (one price for 10 or 500, so the more you buy the cheaper)
ALL STAINLESS
6mm- 1.00 X HEX HEAD (STAINLESS)
6mm-1.00 X 20 HEX CS (SS)
$0.17 x10= $1.70
METRIC STAINLESS LOCK WASHER
M6 (STAINLESS) LOCK WASHER
$0.06 x10= $0.60
METRIC STAINLESS FLAT WASHER
M6 (STAINLESS) FLAT WASHER
$0.05 x10= $0.50
List with prices
OK here is two list of bolts from the Allen Fastener place posted by thecrazygreek.
Stainless Vs Zinc. Bottom line: For the amount listed there is only $63.50 difference between them!
I have an email into them asking if these are JIS. I don't think they will be.
Bolts
Size x pitch x length $(SS) $(Zinc) Qty
6mm x 1.0 x 10mm .12 .07 50
6mm x 1.0 x 20mm .17 .11 100
6mm x 1.0 x 25mm .17 .12 50
8mm x 1.25 x 16mm .24 .31 50
8mm x 1.25 x 20mm .25 .35 100
8mm x 1.25 x 25mm .28 .36 150
8mm x 1.25 x 30mm .29 .37 50
8mm x 1.25 x 35mm .30 .48 100
Flat Washers
Size $(SS) $(Zinc) Qty
6mm .05 .02 200
8mm .08 .03 450
10mm .14 .05 75
12mm .22 .08 25
Lock Washers
6mm .06 .02 200
8mm .12 .03 450
10mm .18 .06 75
12mm .22 .07 25
Total for all Stainless = $302
Total for all Zinc = $238.50
Not bad for 2150 pieces! Great find there `thecrazygreek! :cheers:
Its thecrazyGREEK!!!
NOT GEEK!!! :flipoff2: hehe...
I still havent found a better deal anywhere on the net. And to top it off, they are quick to ship, and quality seems to be top notch.
:cheers:
Just a question about Zinc vs. stainless. Is there a difference in the strength of the bolt due to the difference in alloy? Any metalurgists out there?
:cheers:
:whoops: pardon me! Guess I need to get better bi-focals? :D I have fixed the post!
I'm placing an order tomorrow. I'm tired of all the searching and don't think anyone will best that price soon.
Yes there is, the zinc bolts are stronger and should be used where critical strength is an issue.
I didn't see a listing for the bolts to hook the engine to the engine stand.
They are 12X1.75 80 - 100 mm, depending on the configuration of your stand.
Also, they should be hardened, not your standard off the shelf bolt.
Few more I got tonight:
Dimmer switch mount
(2) 6 x 1.0 x 12mm split +flat washer
Flasher Relay mounting bolts
(2) 6 x 1.0 x 16mm split +flat washer
Fuse Block mounting bolts
(2) 6 x 1.0 x 12mm split washer only
Gas Pedal mounting bolts
(2) 6 x 1.0 x 16mm split washer only
+12V Power Outlet mounting screws
(2) 4mm x .7 x 10mm phillips head screw w/internal toothed washer
Couple more from last nights work.
Passenger side Engine Lift Hook/ 2F Alternator bracket mounting bolts
(3) 10mm x 1.25 x 30mm split plus flat washers 14mm head if JIS but 17mm fits with no clearance problems
Carb Cable retainer on firewall
(2) 6mm x 1.0 x 20mm split washer only
Few more from yesterday.
Steering Column to dash mounting bolts
2 8mm X 1.25 X 30mm Captured flat washer
Glove Box Door GearShift Plate
4 3mm X 0.5mm X 8mm Split,Flat + 5.5mm nut
Glove Box to Dash Mounting Screw
3 5mm X 10mm Sheet metal screws Split, FLat
Glove Box Limit strap (wire) rope) Mounting
2 5mm X 0.8mm X 10mm split only + 8mm nut
Glove Box Knob
1 4mm X 0.7mm X 20mm Molded in stud Split, flat + 7mm nut
Brake Pedal Pivot Bolt
1 10mm X 1.25 X 80mm with 60mm shoulder. Bolt is .485 diameter 12mm head
Clutch Pedal Pivot Bolt
Brake/Clutch Pedal Pivot Sleeve
1 0.510 outside diameter X 1.975 length Inside diameter= 0.397
Brake/Clutch Pedal Nylon Bearing
2 ea
Cowl Vent lift sleeve anchor screws
4 6mm X 1.0 X 12mm Split, Flat Phillips Head
Cowl Vent Door mount Nuts
2 4mm X 0.7mm X NA 7mm nut size
Radiator U Frame to cross member Nuts
2 8mm X 1.25mm X 25mm studs welded to bottom
2 nuts 14mm heads Split, flat
Fan Shroud to Radiator U Frame bolts
6 8mm X 1.25 X 20 mm Split, Flat captured
Radiator U Frame top Cross member bolts
2 8mm X 1.25mm X 20 mm Split, Flat
Small front shroud to Radiator U Frame screws
6 5mm X 0.8mm X 10mm Split Only Phillips screw
Bib Hinge Mounting Bolts
2 8mm X 1.25mm X 30mm Shoulder = 15mm Split, Flat. 12mm bolt head
That's all for now...
Thanks CM.. .all this much appreciated. I have to do some ordering soon so I need to go back to Melissa's excel file.
I think she mentioned a place (maybe on this thread..I'll have to check) that charged no shipping????!!!! If so.. wonder if there is a limit to weight... b/c I'm gonna give them one, very large, order.
Much appreciated.
Scott
Bump
Come on folks lets finish this! :bounce:
Remember we need ALL the information about the fastener! Use metric!
Year and model of truck
# used
thread diameter (3, 4, 5, 5.5, 6, 7, 8, 10, 12mm)
thread pitch (0.5, 0.7, 1.0, 1.25, 1.5, 1.75mm)
total length of bolt (8-100mm)
length of shoulder (no thread area) if bolt has one
washers used (split,flat, internal toothed)
Head diameter (wrench size) if larger head will fit say so. That way one knows if a non JIS bolt will work
nut size (wrench size) if nut used
By the way the US is one of only 5 countries in the world that still use English measurments!
NASA recently stated that an international commitee has declared that any future mission or base on the MOON be metric.
Land Cruiser Moon Buggy? :grinpimp:
Top Vinyl dash piece to body screws
5 5mm x 0.8 x 15mm No washers? JIS Phillips screws
5 plastic sleeves cone shaped. Lines the hole in dash
Fold down Wind shield knobs
2 8mm x 1.25 x 70 mm studs molded into knob w/40 mm shoulder. Knob is 50mm in diameter
Emergency Brake bracket (top) to firewall
2 6mm x 1.0 x 16mm 10mm head. Flat + split.
Emergency Brake bracket (bottom) to dash
2 6mm x 1.0 x 20mm 10mm head. Flat + split + 10mm nut
Vacuum T-case shifter lever assembly to firewall bolts
2 6mm x 1.0 x 16mm. Flat + split.
Vacuum T-case shifter linkage pivot nuts
3 8mm x 1.25 12 mm head nuts. Split washer only
Body Mount bolts
12 10mm x 1.25 x 50mm. w/23mm shoulder. Flat + split washers
Note: Tip of OEM bolt was ground to a point to aid in inserting the bolt up through the mount and into the captive nut.
All for today!
Top Thermo stat housing to lower housing
2 8mm x 1.25 x 45mm w/12mm shoulder. Split only. 12mm head
Lower thermostat housing to block
2 10mm x 1.25 x 25mm captured split. 14mm head
Oil Filter bracket to Intake
3 8mm x 1.25 x 23 (use a 25mm) Split only. 12mm head
Oil pressure regulator to block
2 8mm x 1.25 x 23mm (Use a 25mm) captured split. 12mm head.
Clutch Slave Cylinder to Trans Mount
1 10mm x 1.5 x 55mm w/25mm shoulder. Split only. 14mm head
1 10mm x 1.5 x 10mm thick nut
1 10mm x 1.25 x 55mm w/35mm shoulder Split only. 14mm head
Rubber Windshield Rests to Hood
4 8mm x 1.25 12mm heads. 13mm will fit.
4 8mm split washers
4 8mm flat washers
Studs are molded into rubber and are 8mm x 1.25 x 20mm (exposed)
F Engine Water Pump to Block
4 10mm x 1.5mm x 35mm w/10mm shoulder. Split only. 14mm head
1 10mm x 1.5mm x 60mm w/35mm shoulder. Split only. 14mm head
Windshield Hinge to Windshield frame
16 8mm x 1.25 x 15mm Pan head Phillips screw. Cone style star washer.
Hood Hinge to Hood
12 6mm x 1.0 x 12mm Pan head Phillips screw
12 6mm split washers
12 6mm flat washers
12 6mm x 1.0 nuts. 10mm head
Split Hood Chrome Ornament to Hood
3 6mm x 1.0 x 20mm bolts (captured in ornament)
3 6mm Split Washers
3 6mm Flat Washers
3 6mm x 1.0 nuts. 10mm head.
Door Hinge to Body
16 8mm x 1.25 x 20mm. Captured split and flat. 12mm if JIS but 13mm Fits.
16 8mm Split Washers.
16 8mm Flat Washers.
Door Hinge to Door
12 8mm x 1.25 x 20mm Internal toothed washer. 12mm head. 13mm will fit.
Engine Splash guard to frame
2 6mm x 1.0 x 16mm captured split and flat. 10mm head.
Inspection cover to Engine Splash Guard
4 5mm x 15mm sheet metal screws. Split Washer. Phillips head.
Triangular Bumper Support to Frame
2 8mm x 1.25 x 20mm 12mm head but 13mm fits.
2 8mm Flat Washers
2 8mm Split Washers
Note these are for the front.
Ignition Coil Bracket to head
2 8mm x 1.25 x 16mm Captured split. 12mm head
Clutch Arm Boot Retainer to Bell Housing
2 6mm x 1.0 x 10mm Captured split. 10mm head
Bell Housing Vent Cover to Bell Housing
Intake/Exhaust Manifold studs in head
6 10mm x 1.25 x 35mm to 12mm x 1.25 x 10mm (double ended studs)
2 10mm x 1.25 x 35mm
8 10mm Brass nuts. 14mm head
8 10mm x 3mm thick washers
Note: these are for my stock F engine with Man-A Fre headers!
:cheers:
I saw tranny tunnel does that mean tranny hump? I have a fiberglass body and my tranny hump is held down with M8 i believe to the body by Extruded U nuts. I'm not real sure about the thread pitch because mine were so rusted I couldn't tell if they were even hex head bolts or not.
This is what I ordered and fit great. Toyota wants $18 something a piece for these.
http://store.nutsandbolts.com/extruded-u-nuts-auveco-11630.html
Orded 3 sets of these bolts also: http://store.nutsandbolts.com/metric-flange-bolts-jis-graded-10-9-0006.html
it was $41 shipped
I guess mine is wrong on the fiberglass tube i have M8 and you have:
Trans Tunnel Bolts
16 6mm x 1.0 x 20mm split washer + flat
Very good thread
