Hey guys,
I just regeared my truck, and it's making noise. It only makes it above around 30 mph and is a constant hum that drops in frequency as I decelerate. It sounds like it's coming from the front diff which is strange since I thought noise usually comes from the rear It doesn't make noise if I accelerate hard for some reason though. It's not noticeable at times but can be quite noticeable at other times. There was alsp a little bit of grinding noticeable at first on deceleration but that's not as frequent now. I'm not sure if this is common with Nitros or if I just need to break them in for 500 miles. I've put about 100 on them so far. I also did a front axle rebuild at the same time by the same mechanic if that makes a difference. Also, it's got cheap gear oil in the diffs right now for the break in period. Is this a bad installation?
Thanks
Thanks
