- Thread starter
- #41
Functional & esthetic
Did you get a weight on that guy?
Not yet, but I’ll definitely get these puppies on a scale before mounting.
Lookin good sir!View attachment 1720630
I picked up a Hobart handler 190 at the start of this job. Welds are nothing to write home about but definitely getting better.
$1500 later I now have a spare I can count on..... and a trasharoo. My instagram is seak_the_peak_overland, how could I claim to be an overlander without a trasharoo!?!View attachment 1705532
It’s seek_the_peak_overland. And thanks!I tried following you on IG and couldn't find you!
I would love to be able to lay beads like that. Nice work !!!View attachment 1720630
I like the oil filter access you did. Nice and clean. Probably the only issue I see is the small access to the drain plugs. They are nice because of protection, but may get spillage onto the rock shields when draining. Doesn't look like a huge project to remove if needed for your PM'ing. Nice work !!!!View attachment 1723008 View attachment 1723009 View attachment 1723010
It’s all in! I’ll probably add another bracket or some bolts in the rear to strengthen the mounting.
Yeah I went back and forth on hole sizes. These are 3” hole now. If it too big of a headache to service I’ll break out the plasma cutter and open them up some more...... which means I get to play with the plasma cutter again!I like the oil filter access you did. Nice and clean. Probably the only issue I see is the small access to the drain plugs. They are nice because of protection, but may get spillage onto the rock shields when draining. Doesn't look like a huge project to remove if needed for your PM'ing. Nice work !!!!![]()
Nice. You're a good friend to have.Bring on the weekend!! I’m also building a friends truck. View attachment 1724006
I did. The Slee was on his and we just swapped. He didnt like the 18 step process to load things in the cargo area.Nice. You're a good friend to have.
Did you by chance give him your stock bumper? I like the white on graphite.
we use stoptech on my dads Sequioa. Works pretty well.Has anyone tried these stop tech rotors? I smoked my last set pretty quickly with this tank. View attachment 1718305
