- Thread starter
- #61
Interested hear your thoughts on the radflo's when you get some miles.View attachment 1837281 View attachment 1837282
Picked up a set of metal tech rear LCA’s and some extended travel radflos for up front.
For sure! I still haven’t mounted them but I have high hopes.Interested hear your thoughts on the radflo's when you get some miles.
That M12 is in a whole other league than that VR! .. as are the rad flo’s compare to omeUpgraded from the Warn VR10s to the M12. View attachment 1845925View attachment 1845926
I realize this post is 8 months old, but I was curious about your rear locker magnet fix. Did you remove the entire actuator or is it possible to just remove the protection plate and just remove the 3 screws on the armature cover to check the magnets? I'm trying to diagnose my issue (light flashing but not engaging) with the easiest steps first then on to the more difficult steps. ThanksView attachment 1705418 View attachment 1705419 View attachment 1705420 After plunging into Goose Creek in Fayetteville TN, I decided to make a huge hole in my passenger fender and stick a tube in it.
Also the rear locker wouldn’t engage so I pulled it apart to find the magnets in the motor were broke. I took the biggest chunk of magnet and epoxied it back in the case and it’s been working fine for the last couple years
You have to remove the entire locker assembly. Repairing the motor was not that difficult, but getting the actuator rod adjusted was a pita.I realize this post is 8 months old, but I was curious about your rear locker magnet fix. Did you remove the entire actuator or is it possible to just remove the protection plate and just remove the 3 screws on the armature cover to check the magnets? I'm trying to diagnose my issue (light flashing but not engaging) with the easiest steps first then on to the more difficult steps. Thanks
So, I’ve had the radflos for 5k Miles now and they’ve been great. Way smoother than the ome’s (no surprise). No issues whatsoever and the extra droop has helped me up some more challenging trails.Interested hear your thoughts on the radflo's when you get some miles.
I ordered the antenna base from amazon and and got the mast from a friend who had changed his out.I need to do that Mod! where did you buy your parts from?
I gues in theory the A arm can droop 90 degrees if everything attached to it were disconnected. When you pull the front suspension, you’ll notice that the travel is much longer with the shocks removed. These are extended length over stock or the ome’s I had previously. I can’t remember my exact measurements not, but I think it gave me roughly 2” more travel. I can definitely tell off road or when trying to jack up the truck.I always thought the front droop was limited by the A arm, how much extra droop were you able to get out of the Radflos? Trying to decide on shocks for mine...
Would you mind sharing the link?I ordered the antenna base from amazon and and got the mast from a friend who had changed his out.
