“New” Redline 2.5” suspension kit
Finishing up the install. More pics to come. Happy with the Redline Kit, talked with them on the phone a couple times during to clarify a couple things.
The leafs wrap partially around the main leaf, so that is supporting the main leaf completely. The spring eyes are much larger than stock which will help the bushings last longer than the far too small stock bushings and make for a more stable ride. Im guessing with the larger leaf eyes a military wrap wouldn't fit in the stock fj40 mounts. I've not seen many modern leaf springs crack unless they have like 500k miles on them except composite leaf springs. But if you have a very specific leaf design in mind it is probably best to have them custom made rather than use a off the shelf lift spring.
This kit really looks great. I was very close to picking one up earlier this month I changed some things on my 40 and used some springs I had. It rides much better now, not sure it is as good as these would, but I like the ways these look better than others on the market. Reading and knowing how spring packs should be made, these look like they check all the boxes.
