New Dobinsons VT series dual rate coils (8 Viewers)
37s should fit pretty easy.
Like Gary said your coils most likely need to be swapped side to side ;)
You should not be haveing that much deference side to side !
I'm not sure how much was trimmed off the fenders - that work was done by the PO. He was running 36's at one point and he wheeled hard - but had a little more lift going on than I do now. Bump Stops are already lowered by 2" from stock. You weren't suggesting lower them an additional 2" were you? I will probably have to just try 37's and see how we do.
I thibk I've seen a picture of that rig, it had TSL Swampers... If you have 2" bumps your set.
I’m reviving this as I think a heard there may have been another change in these VT Springs? Also, I imagine others have put some miles on their set ups now and have some more input or opinions.
I’m switching my OME suspension over to Dobinsons and have settled in the VT. I have 37” tires, double cardan driveshafts, Slee 4” caster plates, extended brake lines, yada yada yada. Weight wise I have a Slee front bumper and winch, sliders, Prinsu full rack, 4x4labs rear without swing outs, spare tire in cargo area with rack and a fridge. I noticed there is a 4.5” , but 4” rear springs or 3.5” front and 4” rear. Can someone in 37’s chime in on what they went with and what worked. Also, it seems there are mixed reviews on whether to get the 4-5”
Shocks or the 6-7” shocks. Any input is appreciated.
I have the VT coils 2.5 lift with a 1" body lift and clear 37 with a little front fender trim. I gained 4" with just the springs but they do look like they are settling. I only had then for about 2 months
