Well,
Robbie has most likely identified the source. He was kind enough to examine a bare block that was available.
There is an oil galley that feeds the oil cooler. That galley is cross-drilled from the front face of the block and then plugged with a cup-type freeze plug of about 16mm. That plug is covered by, but not sealed by, the timing cover.
What has most likely happened is this plug has come loose and was stopped from coming completely out by the timing cover. Oil is then peing pushed past the loose plug and then flowing down the small gap between the front face of the block and the timing cover and then exiting at the notch at the bottom.
The timing cover must be removed as well as both oil pans. The engine will have to be let loose of the front mounts and jacked up a bit to allow removall of the upper oil pan.
Robbie indicated that it is possible to remove the timing cover without removing the head using this approach.
My strategy at this point is to go up from below and see if I can do it without damage to the head gasket. If I can, GREAT. If not, I still need to get the bottom end apart anyway.
Oh, the plug in question is NOT serviced by Toyota. Ya gotta buy a block to get it from them
So don't tell anyone but I'm gonna find something aftermarket.......... :whoops:
D-
