- Thread starter
- #141
88440-26090
This post was in 2009..So I wonder what The Dan looks like now In 2022? lolDamn this is an old thread, back when Dan had gray hair and was bald.
I can safely tell you that the truck has aged better than I have. Getting ready for Cruise Moab 2022.This post was in 2009..So I wonder what The Dan looks like now In 2022? lol
The rear pan arch on practically every factory-assembled 1FZ leaks. Mine was leaking 19 and a half years ago when I did the job. I just took this photo. View attachment 2973029
Nice camper!I can safely tell you that the truck has aged better than I have. Getting ready for Cruise Moab 2022.View attachment 2973013
2002 Kimberley Kakadu. One of roughly 12 imported in 2002. At one time Romer had it's litter mate that was 4 units away from mine.Nice camper!
Some of the most well made campers out there.2002 Kimberley Kakadu. One of roughly 12 imported in 2002. At one time Romer had it's litter mate that was 4 units away from mine.
I just replaced the original Australian-made Goodyear Wranglers a couple weeks ago. They still looked good but they were starting to scare meSome of the most well made campers out there.
The Emerald Phoenix has risen from the ashes
After 27 hours of ball-busting toil I fired my beast at ten minutes past five pm today.
The oil is NO LEAKY . I have a small coolant leak at the water by-pass pipe that I half expected and that is an easy fix.
Stuff used:
One each, 42 cent 5/8 oversize shallow cup freeze plug.
One each, Permatex sleeve retainer (green)
Two each, Toyota FIPG sealer.
Two each, antifreeze.
Two each, gallons distilled water.
Eight each, quarts motor oil.
One each, oil filter.
Three each, timing cover O rings.
One each, timing chain slipper.
One each, timing chain tensioner.
One each, timing chain tensioner gasket.
One each, front cranksahaft seal.
One each, water pump & gasket.
One each, Alternator belt idler pulley.
One each, set of drive belts.
One each, water bypass gasket.
One each, water housing gasket.
One each, dip stick tube O ring.
Three each, radiator hoses.
One each, coolant bypass hose.
Six each, radiator hose clamps.
One each, supercharger crossover gasket.
Six each, sparkplugs.
One each, valve cover gasket.
Three each. PAIR injection tube gaskets.
Three each, bypass pipe o rings.
One each, Sylglide.
Five each, brake parts cleaner aerosol cans.
One each, Locktite blue thread locker.
Three each, razor blades.
One each, PS pump O ring.
One each, oil drain plug gasket.
Twelve pair each, nitrile gloves.
Three each, large bandaids
One each, blue sweatshirt. :whoops:
A VERY SPECIAL THANKS to my dear friend and fellow Garand collector Todd, who offered me a lift in his garage and a bunch of special tools and a very valuable hand in times of need.
I HOPE that nobody else EVER needs to do his job, It was a screaming Beach.....
D-
Awww bummer.I'm afraid you are not going to like my answer.
This was almost 19 years ago and I don't remember the gory details.
