Dave 2000
Not all Land Rovers are useless!
- Thread starter
- #101
This weekend saw the install of a 150 amp alternator, Blue Seas split charger, and NL battery monitor
So get the
ready:
Well I got to work with installing the above components, whilst in there I also replaced all the battery cables and put in a heavier alternator cable. All cables were run down and behind the radiator so there are no cables running over the fan shroud, the heavier gauge will allow for the extra distance. Later I plan to try twin electric fans and did not want the cables flapping about in mid air when the shroud is removed. The alternator was a breeze to fit, just a simple mod to the adjuster bracket saw it all done and dusted, I have ‘lost’ the bolt adjustment and have to adjust with the ‘old fashioned’ method. I will at a later date fab up something that gives me back the bolt adjust which would make maintenance easier in the future. I did not manage to renew the starter cable so that can be done when the contacts are changed, incidentally the non start situation I experienced a few weeks back has still to rear it’s ugly head?
The Blue seas split charger was another easy install, it is great unit that senses either battery being charged, if I connect a mains charger (or any charging source) to either battery whether the ignition is on or not the batteries will parallel so they both get charged. I plan to fit a solar panel at a later date and the obvious objective is to have the batteries receiving a charge if the engine is running or not (daylight of course), this should result in batteries being maintained at peak charge. This particular split charger also allows you to parallel batteries for hard starting scenarios (remember my car has a 12 volt starter) but the parallel function will not parallel if it detects one of the batteries has a very low voltage, this prevents the ‘bad’ or faulty battery pulling down the good one. As per marine guidelines this parallel function can also be initiated by manualy pushing down a button on top of the unit. I hope not to need it as the idea of having the now ‘spare’ battery is to run a fridge/camping lights ect.
The NL battery monitor was fitted to the right of the gearstick and the Blue Seas override switch just below, as with pretty much any small LED’s they are difficult to see in the daylight/sun on the NL unit, fitting them as I have means they are pretty much shaded by the overhang of the dashboard but are perfect to see at a glance whilst driving, having said that the unit has an alarm for over/under voltage so I doubt it will get looked at that much but it is a functional and tidy looking unit. I do not really like the idea of gauge duplication (two volt meters for the main battery) but of course the NL unit is graduated and of course works without the ignition being on so the true battery voltages are shown so the condition of the batteries can be seen before starting/charging ect. The new wheel studs/nuts along with the starter contacts have yet to arrive from Toyota but I still have some other things to do, the extra interior light for the rear has to be fitted as does the cable for the ‘shark fin ariel, I also need to run some heavy cable to the rear to power the extras. I still need to find some decent batteries and as Bosch do a good range over here I thought I would perhaps get a good deal but need some advice before fitting however, trying to get information from there tech dept is like getting blood from a stone! Other than that it was a productive weekend, hopefully I will get the time to do some more next week?
Regards
Dave
So get the
Regards
Dave
