my HJ60 revival (build?) (11 Viewers)
The 5 speed is all over the place down here in the states. It’s still available new from Toyota. You should be able to get one up there.
Unless you’re set on finding a used one.
I Don't have the money for a new one 😅 only reason I can afford a truck like that is because I can fix it or make parts most of the time. 😅
I get it. I only got one because I was living in the damn thing in 2020. 🤣
Seem the guy selling me the part truck might have a H55F and a 2h ... These have been in a fire tho... The barn where they were stored burnt down ... He said the transmission might be good ... The engine is not .. but at least I have a Flywheel 😅
Bought a 5 speed ! Hoping the part truck will have what's missing ( except the flywheel obviously) at least it's a 2h Bell housing and front shaft.
Few questions still ... I found a 10 splines clutch on Rock Auto .... Seem to be unsure if it fits ....
Also , will the shifter from the 4speed fit in that cover ?
View attachment 3932061View attachment 3932062View attachment 3932063
wow sorry to hear of the bad luck! But glad you found a 5 spd! I hope you're able to get it on the road again shortly to see out the rest of the summer!
AHAH believe me im a damn workaholic... 2 week downtim MAX.......
I see a lot of twin shifter T-case mods too... I should be good to keep the vacuum actuator witch I already have in my truck for now.
I read in other threads that the swap would be bolt on in a truck with a 4 speed manual so the part truck sould complete everything i need (🤞)
Feck yeah! That’s awesome!
You need a 5 speed shifter. Might as well get the new nylon bushing while you’re at it. The 4 speed won’t work.
If it's only that ... Sure will change the bushing ahah. I will try you source one locally ... Might be lucky 🤷
The bushing wears out and the shifter will drop making it tough or impossible to shift. I bet you find a shifter up there. That was fast with the transmission.
Welllllll , sorted a few things
First we are on our drive back home from getting the part truck witch is not in a crazy bad shape !
And about the shifter issue ... The guy had another H55F laying around in his shed and that one had the shifter on it ... So I stretched the budget a bit for a set of the right driveshafts and I grabbed the H55F too 😅
So.... I'm still missing a 2H flywheel .... Anyone ? Please ? 🥲
Will probably modify the transmission cover instead of using the manual one I have .... Mine is cleaner ... Anyway .. still on the hunt for a flywheel
Transmission should be on the ground tonight and the engine will be holding on a jack stand under the truck till I find the missing link. Will update later today
Damn.. not the update I wanted to see.. :(
You'll have to sort out a revised cross member as well.
That I can make one in not really worried about it 😉 the flywheel is another story .... Plenty of 2F ... No 2H 😭
Anyway ... More progress than I expected tonight :) A/T is out ... Took 1h and a half
Victory burger !
Then we start picking parts from the donor truck :)
More progress coming ....
About the failure .... There is what ****ed the s*** up ...
We can see the flexplate holes got beaten up too.....
Importance of using the good bolts.... Had my lesson .... And a reason to get rid of the A/T 🤣
Aint nobody got time for an A440F behind a 2H..
Positive step forward!
I am interested in finding out how your throttle will react with the new arrangement - the 2H auto pump is much like the 12HT pump. Following with interest.
I don't think the pump is gonna care much .... The kickdown cable is rigged on the linkage but not to the pump. I have a MT pump too but I rather keep that one ... Anyway nothing transmission related is rigged to the pump 🤷
You don't have a Flywheel by any chance @duncanrm 😅
I have 2-3... I'd hate to think what the freight would be though, or who'd I'd use.. do you want me to try and work it out?
