been doing a bunch of work on my 60 lately, going through desmog stuff again,
Adding BVSV1 back into the circut, that should help cold weather driveability this winter. If you are BVSV'less like i am and drive in the cold, even with a ported vac source it can be hard to keep the engine running when you first set out..
found my intake / exhaust mani gasket had failed pretty badly, so replaced that with OEM toyo gasket and had my mani milled flat, sealed nicely now - likely for the first time ever since i did my original desmog back in 2009.
did a lean drop and retune of the carb after i sealed up all the vac leaks from the manifold,
here's where im at , and ive got a question for Jim or anyone who may know..
when i pull my choke 90% of the way on a hot engine, i get the corresponding idle up to 1800-2000 rpm as it should.
If i pull my choke 100% , it will kill the engine, hot or cold. so - is this an issue with the choke opener or choke breaker? how should i trouble shoot that? or should i..
