lrowe_csp said:Nice paint job on the trim pieces! For posterity and assistance to other cruiserheads who may need to do this with their cruisers, what brand, type and color of paint did you use?
What does the switch in front of the elec window switch do
I'm guessing it's a door lock/unlock switch.
Don't know why other markets didn't have it.
Something I've been wondering, is there a write-up on installing an aftermarket head unit (Basic Pioneer) in place of the original Toyota unit (CD/Tape/EQ/Tuner) while still using all stock speaker locations.
From what I understand, if I want to run an aftermarket radio, I can not use the factory Amp which powers the 3 rear most speakers?
I removed the radio to install the new power antenna, and wanted to know what these other two plugs are for (Two on the Left) I know the one on the right is for the radio.
Any insight on this would be wonderful, as my radio is garbage and most of the speakers are damaged from the previous owner.
Cheers,
-Tom
You can go here and see if it's any help,
DSCN2722 | Flickr - Photo Sharing!
1991-1992
First major wagon body re-design since the 1980 introduction of the 60
series.
3FE 4.0L engine and A440F automatic transmission held over from the 62 series wagons.
Introduction of full time, four wheel drive system.
Introduction of all coil suspension for the wagons.
15" x 7" alloy wheels standard and unique to '91-92 but the same as SR5 mini-truck wheels
front disk / rear drum brakes with FF front and SF rear axles
third row seats available for the first time
no airbags available
no ABS brake system available
no factory lockers available
TheLoyale said:I was poking around Slee's website out of shear boredom, and I found this info about the '91-'92 FJ80s. And noticed it said that they have a Full-Floating Front Axle and Semi-Floating Rear axle (Highlighted) Is this true? I thought the FF axles were only on the '93 and up with the lockers? Still new to Land Cruisers, so I don't know all the nitty gritty details yet.
All front steer axles are full floater, rear axles on the fzj80 became ff in '93
