Builds My 1975 lazy style revival thread (1 Viewer)
Rear is all sealed up and got new brakes. Just need to add oil with LSD additive, bleed brakes, and possibly adjust.
Not much is different visually, but I am making progress. Driveshafts are cleaned, painted, greased and bolted in. Everything that requires gear oil is now full. Brakes have fluid. Still need to bleed and adjust though.
I am looking forward to getting alot done over this Labor Day weekend.
Made a fan shrould for the electric fan that came on this truck. I hate fans mounted directly to the radiator core with zip ties. Plus there's a gap behind it so it should have good flow.
New oem cap too. I prefer the earlier style with the writing and symbols stamped in....plus the chain.....but I had this one already.
Alittle bit everyday.......got the new turn signal and ignition switch installed under the refinished column covers. Steering wheel is pretty rough, so I'll get to that later. Back on the ground with a relative in the background.
