i just snapped one i just replaced gonna bolt it.
what size bolts are you guys using?
i am about to do both motor mounts and i plan on doing the modifacation you guys have described.
I bought an after market MM, drilled a hole through it, tried to install and it was not even close to lining up with the frame mount hole. Comparing the aftermarket to the stock mount i noticed the aftermarket mount bolts are offset 1/8" and the stock are around 1/2"...all after i did the drilling.
Threw the old one back in and i am wondering if the FJ62 mounts are different than the FJ60 mounts. I am exhuasted so i may have missed something.
Anybody got pics of the chain method (Tring to get to katemcy any way i can this weekend)?
How long does the strap method last?
Thanks
Charles
i think the 62's are slightly offset and the 60's are straight. as i had a 62 motor mount on my 60 it was kinda a pain to get on but once it was on no problems (till it ripped) then i got a 60 mount and drilled it and bolted it down.
tho even if the 62 is slightly offset you should still be able to get a bolt through it at a slight angle and not have any problems. so maybe give that a shot.
