- Thread starter
- #1,401
I do what I can let me know about that 203..... I may need that adapter on it for my own diesel conversion project.
what are the plans with the H55?
Will do man.
I intend to sell the H55. Want it?
Will do man.
sure!!! three easy installments of $19.95 ok??
To get the broken bolt out keep using a slightly bigger drill until you can turn the remains out.
So at one point the remains will start to turn and if it does not happen use a larger drill. If you hit the side it is no drama, it will wire itself when you bolt a new one in. Most important is to start drilling with the smallest drill exactly in the middle.
What you remove can not be replaced but if it does not cooperate use force and agression.
or a helicoil
https://www.youtube.com/results?sea.....0.0.0.6712.0.0.0.0.0.0.0.0..0.0...0.0...1ac.
If you hit it sideways with a drill you break the circle that keeps it strong and it will definetly go, you are almost there
Looking good Johnny, Whats the timeline to get it running in MoonShine?
J
Those cylinder walls look great. It's interesting to see the spray pattern on the pistons too. Also interested to see how the HX30 is going to do. Should be quick spooling which is nice for a driver.
How hard were your injectors to pull out? I see you made yourself a puller.
How many miles did you say that engine has on it? There is still original cross hatching on the cylinder walls! That engine wasn't even broken in yet!
Did you get your overhaul kit yet? I've got a couple of companies with good prices for those. Are you going with the same pistons? Injectors? I changed mine to what was in the dodge cummins 6bt ('94 through '98) for a little more go.
You are at a fun stage, the tear down and build back up.
I have not purchased my overhaul kit. Where'd you get yours? I haven't decided if I am going to replace my injectors or rebuild them.
That's just sexy johnny!
J
Nice looking turbo, pull that silencer ring to really hear that whistle.
Thanks guys!
Not sure I want to modify it yet. Can the silencer ring snap in and out? I am 100% new to the world of turbos, so please educate me![]()
Johnny you can take it in and out.. Should be a tension ring holding it in place.. It'll make a difference in sound for sure but, not on power..
http://www.youtube.com/watch?feature=player_detailpage&v=0lP3fA06rYU
Here a vid on a Holset silencer being removed on a 2000 Cummins I believe. ENJOY...
J
