Mike's 1978 FJ40 Build
This afternoon I fitted the new throwout bearing on the old hub after pushing out the old throwout bearing.
Then I attached the hub and throwout bearing with the little wire clip to the fork.
The clutch fork arm is completely assembled with throw out bearing and holding pins.
FYI don't need a strap when using an impact. Another FYI-on bolts this large inch sizes work fine. Don't know what 46 is in inch though.
I had to use the strap to hold the pulley in place since the flywheel and tranny is not installed as yet. I tried without the strap and the pulley would turn slowly and the impact wouldn't remove the nut. As soon as I tied down the pulley the nut came right off.
full
46 mm = 1-13/16"
I finally removed the timing gear cover and cleaned the end plate.
Removed old seal cleaned and painted timing cover.
When and where did you reinstall the slave and fork?
Did you mount that on the transmission
Or the bell housing?
I'm a bit lost with thus and how it all get lined up
...via IH8MUD app
Next step is to deal with water pump installation and also remove clean and paint the thermostat housing.
...via IH8MUD app
The clutch gets mounted on the flywheel within the bell housing and then the tranny will slide in the bell housing and bolted in place.
The clutch and tranny installation will be the last thing I do, I'll be taking plenty of pics during the entire installation, stay tuned.
I've been doing a lot of cleaning and painting lately, I need to start re-assembly soon and finish before the winter sneaks in here in the PNW.
Pic of fuel pump prior to cleaning
Fuel pump and oil filter bracket cleaned
Distributor prior to cleaning
Cleaning block surfaces for new water pump and T stat housing
Side valve cover removed for cleaning
A lot of cleaning involved!
Here are a few updates; Yesterday I started the re-assembly process (right side of engine)
Cleaned all components, painted, new hoses, new water pump, new thermostat, new double clamps, new fuel filter and hoses with new fuel injection hose clamps.
Installed timing gear cover and crank pulley
Sorry about the crappy pics, phone camera
New fuel filter (relocated and mounted on the charcoal canister) for easy future access
Today I started dis-assembly of the left side of engine, removed air cleaner housing, removed valve cover and carb.
I will be removing and replacing intake/exhaust manifolds gasket since there's a small leak, it may be a cracked exhaust manifold, I don't know for sure, the exhaust leak appears when the engine is cold and as it warms up the leak goes away. If it's a cracked manifold I might be looking for a new header, but I don't know how that will work with a stock carb.
More cleaning and painting to come, I hate the cleaning part but love re-assembling the engine.
Did you test fit your pilot bearing on the trans before installing it. Sometimes the input shaft? needs to be sanded down for the new pilot bearing to slide onto. Ask me how I know. :bang:
There's flexible connector on the carb where the engine breather tube is connected, it is toast, where can I find a new one, does anyone know?
Thanks for the heads up! Yeah I sure did and it fits perfectly. Does the input shaft need to be lubed for easy install of the tranny into the pilot?
The tranny install will be the last thing I do.
I didn't. Just takes a little patience to get everything lined up and put together.
P
Pulling the tranny was a pain in the arss, I'm sure the re-install will be just as bad, specially trying line it up and push it back in place, I'll be ready in couple of weeks for that part.
