The old lady was 80 and had the car for years and talking to her l found out she had the car serviced at the dealership where l used to work. Then l looked at the service history and found l serviced the car in 99 and 2000, small world
So for the bargain price of $700 l bought it. This model is the later version of the 306 with the 1.8 twin cam and manual, these motors gear boxes are solid and have less electronics than the newer models which l like.
Loaded it up and set off. Towing the empty trailer was not a problem and could easily pass trucks on hills heading out to pick the car up, the power was great. With the car on it was noticeable but just plant the foot and it kept pulling and l was very impressed the way you just sink the foot and send it.
The intake air temps sat around 40 degrees C, coolant temps around 80 and maxed at 86 Degrees C under long hill climbs and full boost, 86 degrees coolant temps used to be what l normally saw before the turbo so very happy. Getting 2 psi of boost starting at 1,900 rpm with full load.
There's a bit of an issue with heat soak on the IAT sensor when you stop and the intake temps go up, looking to do some wrapping or fit a beanie to the turbo to prevent this but its not an issue while driving.
Fuel usage was about 450Km to the main tank towing which was through some hilly back roads. Use to get 500Km from the main pre turbo so happy with those figures, now to add some more boost.
