- Thread starter
- #81
Carpet came up nice after the clean, took the tinny for a run down the river and noticed the new wastegate spring not boosting to the required 7.5 Psi and now running lean on the wideband. Decided to swap the original back but still running lean.
Noticed the fuel pump no longer holds it's pressure once turned off and goes straight back to zero, so thinking the pump has an issue, pressure seems ok but will check flow and voltage at the pump. Has no external leaks and if the injectors were faulty it would be rich. Have been told these pumps can draw a lot of amps so maybe it has caused a problem, wiring looks fine. Will also remove pump and inspect.
