- Thread starter
- #161
Did the ABS unit of the GS look like it would match the 100 series perfectly?
Even if the outside of the ABS unit looks the same, valve sizes or routing inside may be different. The ABS unit also does VSC and A-TRAC, while a lot of functionality is in controllers it may require different ABS valve units. When VSC has problems it can be very scary in panic situations. While some GSs are all wheel drive none have A_TRAC. The Cruiser brakes need more fluid flow. Not just length of brake lines, LC front calipers are 4 piston, GS are 2 piston.
Not to deter you but would hope you do all manor of emergency stops and VSC activation testing, so it does what it is suppose to do when you swerve to avoid that deer on a narrow mountain road with your family riding with you.
