I doubt it. I'm no expert though... Did go through major issues with mine, also a 98 LC however I never lost brake function...
Pretty sure your accumulator or pump motor are no good.Got some great info from the thread. I ended up purchasing a rebuilt unit from Andy Le after hearing some good reviews.
Ive got a 98 model. Recently replaced the unit. Bled the brakes. Everything worked well for a day. Then i lost 95% of braking power. Fluid returned to the reservoir. The pedal goes all the way to the floor.
During the bleeding process i didnt not activate abs and re-bleed. Could this be the reason for my issue?
job. I used a total of 2 quarts of brake fluid, including some to rinse out the reservoir after denatured alcohol.You are welcome.@Skidoo Another thanks from me.
You can fill with a degreaser like Simple Green at 100% Let it soak overnight. Shaking vigorously ever now and then.Make sure to rinse 100 % of SG out with water and dry 100%. You can not leave any moisture in it. Save the uses Simple Green to clean more stuff like power steering reservoir or engine parts.Has anyone seen something like this before? There appears to be some kind of build-up on the inside of my brake reservoir. I don't really see anyway to clean it out, as the reservoir has several baffles that prevent direct access to clean it up.
The brake fluid that I drained out did look clean, but had particles in it as well.
All of this comes from trying to chase down a screeching sound coming from the hydraulic brake booster. It seems to only happen first thing in the morning (hot or cold days) and then never again for the whole day. Even if I'm an out of the car all day long. I've even triggered the constant beep for several minutes until the pump seems to be able to build up enough pressure.
The motor runs great, and taking apart the motor, it looks almost brand new inside (previous owner did say he had the HBB replaced a couple of years ago). I don't seem to be leaking/losing any fluid.
Other than the build up inside the reservoir, I can't see any obvious issues.
The plan right now is to order a replacement reservoir from the local dealer, then fully flush and bleed the brakes
Have you used non-t0yota brake fluid? The OEM 5.1 fluid seems to be the best for seals/master, booster and calipers.Has anyone seen something like this before? There appears to be some kind of build-up on the inside of my brake reservoir. ...
