@silveradofab I agree with @Skidoo and @2001LC could be problematic. Perhaps look for a part number or something in the casting to confirm they are different or the same.
@2001LC my brake fluid wasn't discolored, but there was something suspended in the brake fluid that was depositing itself in the reservoir, and I noticed the same particles located in the brake fluid as I was flushing/bleeding. I agree that those particles could very well be a seal being damaged and the remnants remaining in the fluid. But looking at the diagram, it seems like the relief valve should be opening and preventing an over-pressure, and should be preventing seals from being damaged (unless the relief valve itself is what was being damaged).
I do think that there isn't as much risk in examining or replacing (could be impossible to replace) the high pressure switch. This switch is telling the pump when enough pressure has built up and it should stop pumping. I suppose on one side of it, you could send a signal before enough pressure has built up, but I think you can mitigate that by monitoring the amount of fluid that drops from the reservoir. If that drop remains consistent, I would think that the pressure has built up correctly.
I agree that it is unlikely the switches are replaceable. With the design being 20+ years old, it seems unlikely that we are going to stumble across the solution. However, I don't think I've seen anyone else (or too many others) come to the conclusion that the high pressure switch is malfunctioning causing a build up of pressure. So who knows, we could be on to something new! (trying to remain hopeful in the face of $$$-$$$$ to replace
