kelly saad
Supporting Vendor
I have worked out some solutions to the weight issue of the grille on the LX 98-02. Our hood struts are rated 85lbs, and I have located 100lbs and 110 lbs replacements. This should give plenty of extra power to hold the hood up. My grille is not too much heavier than the factory plastic one, but 8-10 lbs extra is a lot for the original supports.
I have designed a headlight housing to hold a 7” round and a 3-3.5” fog light. It was not an easy task to fit all this in the area, and make it look correct. I built a prototype that took quite a while of fitting, but it looked pretty good. The first set of parts are being laser cut now. I’m sure there will be a few adjustments but should be close. Once this first housing is built, I will have pictures to post here, hopefully soon.
I have the grille designed for the 03-07 but have not cut it yet, and still need a test fit vehicle.
when it’s all done.
