LTO BATTERY group 24 by XS Power
Calgary
Is an LTO a good replacement for a Deep-cycle battery?
price is almost the same between them wondering if its really an upgrade if I switch.
I currently have Northstar Group 24 Deep Cycle
KU NSB-AGM24M
Manufacturer Northstar Battery
Weight 57.100000
Length 10.87
Width 6.77
Height 8.74
Battery Type Dual Purpose Battery
Group Size(s) 24
JIS 48D26R,55D26R,65D26R,75D26R,80D26R
OEM Part Number NSB-AGM 24M
Voltage 12 Volt
Cold Cranking Amps rating at -18°C (0°F) 840
Reserve Capacity 25Amp Draw 160
Amp Hour @ 20HR Rate 76
Marine Cranking Amps rating at 0°C (32°F) 1050
Hot Cranking Amps rating at 26°C (80°F) 1290
PHCA 1500
Chemistry Thin Plate, Pure Lead AGM
Warranty (Months) 36
Core Sku A-CORE
XS POWER LTO
BCI24
Voltage12
Rated Watts1500
Energy Wh70
Max Amps1335
Cranking Amps670
CA Pb Eq1000
Ah6
Ah Pb Eq20
Charge Current10s Pulse – 200A, Continuous – 100A, Max Continuous – 150A
Terminal OrientationLeft Hand
BrandXS Power Batteries
A 6 amp hour battery? That's basically nothing.
A 57# 6aH battery?
Gotta be a typo. 76aH stated separately.
edit:and yes, it seems like an option for deep-cycle purposes. I use AGM's for the same purpose. So far so good.
so apparently LTO and AGM have different discharge rates so just the Ah rating alone is not enough to justify which battery is better I guess it all comes down to purpose
probably a typo on the website I also looked at the other LTO batteries in their XV line and they all show 6Ah.... I would assume the bigger the battery the more AH.
I sent them an email to verify
ok so to my understanding and yes they are rated differently.
AGM has only about 45-50% useable power
LTO has about 90-100% useable power
they do list the LTO as Ah to Lead Acid cell equivalents as
Ah Pb Eq 20
I found more helpful info in this thread. I could still build my own for a much cheaper
