I would love to fit a full Slinky 75mm long travel suspension kit but I cannot afford it. So, I've been looking at alternative shock options that would enable me to achieve a long travel set-up. I do however accept, that I cannot expect to get even close to the Icon shocks in terms of quality, when opting for a cheaper shock.
The Icon shocks used in the 75mm Slinky kit are, I believe, the 56511 which measure 16.850" compressed, 28.170" extended and have an 11.32" stroke. These are considerably larger than the OME L.
Iron Man make a shock for the 80 listed as being for a 6" lift with the following specs: Rear 17.284" compressed, 28.740 extended and have an 11.46" stroke; front 16.811" compressed, 28.740 extended and have an 11.93" stroke. See http://cairnstocape4x4.com/files/9814/1211/8058/foamcell-brochure.pdf Now, whilst Iron Man are a budget brand of the same ilk as OME, these particular shocks are their top option and appear to be a fairly decent shock at their price point.
So, if I pair the Iron Man shocks with a set of 75mm Slinky springs, I should achieve a long travel set up as per the full Slinky kit, just with significantly cheaper shocks. Given that I am running 37s I have to slightly extend the bumpstops anyway which will offset the fact the Iron Man shocks are a little longer than the Slinky shocks.
Am I missing anything.....?
