Hojack
♠️Project Snowball❄️
IH8MUDI would lock the rear which is usually sufficient. That cuts your cost in half.
And put a winch on it, because even lockers can't cope with mud.
Not exactly the same since it was an 80 series, but my daughhter and I took her 80 with e-lockers to Drummond Island MI for some wheeling/camping and her rear e-locker wouldn't engage. Climbing some tough rock wall we had to stack rocks a bit mainly because of the non-working rear. No biggie but in that situation, both would have been nice.
Are lockers worth the money? You bet. Do you need them? Absolutely not.
But if you can only get one then winch winch winch. If I was travelling solo, I would take a working winch over a front drive shaft.
My experience is the opposite of many replies above. That doesn't mean their experience isn't equally valid, but take it all, especially my stuff, with a grain of salt.
I started going out in the woods and getting stuck in 1978. I have been in a lot of situations where the lockers weren't enough, I have yet to find myself in a situation where a winch was not enough. I can imagine some, but I have never encountered one first hand.
I have been stuck in Africa a few times, in Land Cruisers with lockers. Deep mud is not impressed by lockers, and they're useless if you get high centered. Thank God we had winches.
I have done a few hundred desert trips in the UAE, you get stuck less often in the sand if you have lockers, but you still get stuck. Then you want a winch. I know people I trust who say that Max Trax are great in that application, but I don't know, I don't have any. I would never recommend a single car trip out there, but I would feel better solo in the dunes with Max Trax than solo in the dunes with lockers.
Thirty years driving in the more damp and wooded environment of the SouthEastern US (where we have a lot more trees to winch to). I winched a lot of trucks with lockers. I have also had a tire over the edge of a cliff, (the access road to Tellico) but for me, it was the winch that saved the day. Would a locker have worked then? I don't think so. I was sideways and off-camber. A locker would have made it worse. winch winch winch.
If you can afford it, a commercial anchor like a pullpal or deadman takes care of 99% of the "nothing to winch to" scenarios. (Avoid the smittybuilt and ARB versions, they are useless.) If you can't afford a Pull Pal, then a shovel and a spare tire will work in sand, mud, or dirt. It sucks, and there is some technique and trial and error to it, but burying a spare will get you out. It sucks so bad that you might do what I did, and run out and buy a Pull-Pal. But it works. Then you might get lazy and leave the Pull-Pal at home and have to bury the spare again. I guess that's how we learn.
A locker will often keep you from getting stuck in the first place, but so will picking a good line, airing down, left-foot braking, good throttle control, scouting dodgey obstacles, using your brain, etc.... But even with a locker you will eventually get stuck. When that happens, the winch is worth its weight in gold. A locker and good driving will save you a lot of blood, sweat, and tears, especially sweat. But you won't realize its limits until you find them first hand. then you will want a winch.
Dry rocks are about the only situation I can think of where a locker might get you through or out of something a winch can't. Simply because you can't bury a spare tire. You also have to get creative if you are stuck in a situation where you need to go backwards. But even these can usually be overcome with some ingenuity.
