Local For Sale/Wanted Section! (9 Viewers)
Hey everyone,
My clutch pedal return spring gave up this weekend - and of course it’s one of those now discontinued/unobtainium parts. I did some digging around McMaster and Grainger but neither of them have a spring with appropriate compressed/extended lengths in a size that will fit.
Anyone kicking one of these around the garage - or know of a later model Toyota spring that will fit? Measurements below. Realistically anything under about 0.6 around with a compressed length longer than 5.8” and an extended length capable of 7” or more should do the trick.
If someone has two I’d take both - if the clutch gave up the brake (same spring) probably isn’t too far behind.
SOR/FJ parts and whatnot appear to have them still, or an aftermarket version - but before I pay $10 shipping for a $5 spring I figured I’d check locally.
OEM PN was 90506-12450 - don’t see anything that supersedes it in the parts catalogues.
Rick send me your address and I'll shoot one down to you. Gary
Thanks Gary - PM coming - maybe you can throw that H41 in a flat rate box with it ;)
@RWBeringer4x4
fwiw, Rick, I drove my 40 for a year without a spring... lost it one day replacing the fuse box and found it a year later under the mat, when I was wiring in a relay for fog lights 😂
Hey everyone,
@RWBeringer4x4
Yeah I was pleasantly surprised to find it really doesn't do much. Was a little concerned it might not allow the clutch master to retract fully, resulting in a pressure build up and the T/O Bearing riding the Pressure Plate - but I haven't seen any evidence of such. Nonetheless, the floppy clutch pedal is annoying and now that I know it's broken...I have to fix it...
Just picked up a barely used set of BFG 37" tires. Only issue is they are for a 17" wheel. Anyone have a set of wheels that will fit my 80 without any spacers or adapters? Ideally 0 offset or 4-4.5 backspace.
Garage sale!
Awhile back someone asked about a diff for their 60. I finally cleaned out my storage unit and found the oem rear LSD from my 1989 BJ74.
Price = a case of something good (not an IPA)
100 series rear springs. OME 863. On the truck for 10k miles or so before going with heavier ones.
(I want to keep the spacers)
Price = a case of something good.
Cool! Can I bring it to fall crawl for you? Or do you want to pack it as carry on when you fly home from CO? :)
1993 80 series project at auction in Maryland
Lot #32
WANTED!
Slee Short Bus 80 series front bumper
Worth a shot...
