Let me start off by thanking everyone on the previous couple of threads that I posted about my carburetor and my brake wheel cylinders because they helped out a ton and I was able to resolve all of the issues.
Now, a new issue......maybe.
I am assuming this truck is lifted. I had a 1976 before and it didn't look like it's at this high but I don't know what the 1970s look like. One thing I noticed is that the front shackles are 5 3/4" inches. If I remember correctly they should be 2 3/4" inches.
Now my truck tracks with the ruts in the road so I am assuming it is because it is lifted and does not have castor shims. By looking at the pictures can anyone tell? It appears to me that the arch of the u-bolts is facing toward the front bumper slightly. I'm guessing this is changing the castor angle and causing this problem.
Should I just install castor shims and fix the problem or should I go back to the original shackles? Will this change anything?
I also included a picture of the rear shackles. Can anyone tell me if these are the correct ones? I can assure you they are 2 3/4" inches though
