The rear shackles are not long enough in theory: Rough Country 4” spring dimensionsI decided not to switch the shackles for now so I can see if it's going to work like that
that wedge is the castor shim that is needed to correct pinion and angle and front axle castor. yes not stock but needed for the longer shackles and lift springs. your springs are too short though and make a very vertical angle. that’s still going to ride harsh.Shackle is not stock, neither is the wedge at spring U bolts.
