Any luck on that bolt?
Unfortunately no... the broken off bit just made things too difficult. Didn't really want to go the torch route because I didn't want all the blowout in the frame. Ended up having my good buddy @SUMMIT CRUISERS Jr and his dad @SUMMIT CRUISERS help me weld the sway bar mount to the frame. I don't see any reason I would ever need to remove it again, so this seemed like the easiest option. 1 hour later and I was good to go.Any luck on that bolt?
Of course! I travel all over the state for work, so the next time I'm heading up to Tulsa I'll let you know!Looking forward to your review. We need to get together one of these weekends, I'm in Tulsa, would love to do a bit of wheeling and could direct compare lifted AHC to your new system.
The review is posted! Once again I would like to thank @reevesci for being accommodating and super awesome throughout this purchase. I recommend Trail Tailor and Tough Dog suspensions to everyone looking for suspension, links, sliders, etc, Jason will hook you up and runs some great deals.
Hopefully I will get some good pics up soon of the new lift height once I get a free minute to wash it.
That's what I figured and experienced with other lifts in the past. I'll continue to report on the suspension and update once I get some weight back there!You are more than welcome C!
The light springs even though rated 0-660# load range will seem bouncy/light with zero load. IMO, just adding 100-200# is where there ride becomes extremely smooth. While a good ride unloaded, it becomes better the more you load it up.
Jason
I broke the same hose on my rack this weekend... glad to see I'm not alone, and thanks for the guidance. I also ordered the same return line & pressure line set from Rock Auto...should be here by Wednesday for a fresh rack install. I'm also having PITA getting the coupling from the column detached...I'm sure I'll get her done today.So heres some photos from my steering rack job. Started it two weekends ago, everything came off smoothly except for the rear pressure line coming from the rack. The line twisted off inside the sleeve, making it impossible for me to know it was twisting until it was too late. Nobody in town had a replacement and I could not form one myself.
I had to leave the cruiser in the garage all week while I waited on replacement hoses from Rock Auto. I went with the Sunsong lines, others have used these on the forum. The lines showed up and were honestly good quality. Everything lined up and works great, I couldn't justify spending another $600 on new OEM lines.
As I was removing the old pressure line from the pump, the banjo wouldn't break before the pressure port union it was screwed into turned. Well after 30 minutes of cussing and cut up fingers, I got it loose. Once I pulled it out, I realized the turn stop thats attached to the line had bent, allowing the pressure air control valve to break.. At this point I am just completely frustrated, thinking I was going to have to have the cruiser down for yet another week waiting on parts. Thankfully the local napa warehouse had one in stock!
With basically a completely whole new steering system besides the pump and reservoir, I figured I would flush out the reservoir real good. I was surprised at how well my fluid looked when emptying it from the system, but I was even more amazed at how clean the reservoir was before cleaning... This pic is before cleaning with degreaser and water.
Hooked everything back up and filled the system. As I began to bleed, the system came to life with the apparent ps pump whine, which disappeared once I bled all the air out of the system.
Wow! I am so happy to have a fresh steering rack in there! It made a huge difference on steering precision and tracking on the highway. Didn't solve all of my issues, but I think they are primarily alignment related. More pics from the install:
FI your talking about the coupling on the shaft, mine was rusted together pretty bad. I had to remove the shaft with the rack and detach the shaft from the rack out of the vehicle.I broke the same hose on my rack this weekend... glad to see I'm not alone, and thanks for the guidance. I also ordered the same return line & pressure line set from Rock Auto...should be here by Wednesday for a fresh rack install. I'm also having PITA getting the coupling from the column detached...I'm sure I'll get her done today.
Best place I found to cut the shocks were right through the bushings and then stem. Its a messy job and the melted rubber from the bushings gums up the blade, but keep a sharp blade on the sawzall and have some patience and it goes by pretty fast.About to dig into this very same job this weekend. I plan to cut the ahc shocks as well, already invested in a mucho sawzall blades.
The front sway bar is the same between LC/LX, so no need to replace that. The rear bar is different by less than 1mm, I couldn't imagine that having much affect. I have not noticed any more body roll than before I removed the AHC. In fact, I have less. I personally believe that your money is better geared towards extended sway bar links.Hey... it looks like I need to go down that route. The AHC delete. One of my rear shock is showing rust through. Anyway almost every other thread I find off the web did not bother to replace sway bar. Why did you choose not to do so?
I came across one of the web says he wished he had replaced sway being that the sway in Lexus is smaller than the Land Cruiser.
Just drove past the "comfort cruiser" this morning after coffee and thought I'd say I love how it is looking. The 4x4 Labs front bumper looks amazing with the wheels!
Thanks guys! I need to post up some pics!I missed this thread earlier - can't wait to read about your build!
I know... I know... I have barely had time to perform basic functions while finishing up this semester, pics will be up soon I promise!uhhh, pics of the bumper? If i can post, you can too DD!
