Media LC 250 & GX550 Picture Thread (16 Viewers)
Photo/Video/Audio threads
It has arrived at last!
First ‘mod.’
Fumoto drain valve going in at 1,000 mile oil change.
I should do the same on mine as it just hit 1k too. I have the fumoto valve already.
So I decided against using the valve until I have real skids. I’m not fond of how low the oil pan is compared to the 200s. Also the new sx valve is pointless, save the money and get the original style on the GX.
Adding further, there were quite a bit of wear metals visible in the filter (and of course I failed to get photos).
Interestingly the truck is telling me my first oil charge is scheduled at 10,000miles; however the service internal in the warranty and maintenance manual recommends 5000 mile oil changes.
Tip, if you have some old garden hose it makes for a good filter drain hose to keep things tidy.
Took delivery last Saturday 7/13 and just got full front-end PPF done. Loving it so far! My previous rig was a 5th Gen 4Runner TRD Pro. Next up - wheels and tires. Going with 18x9 SCS F5 +12 offset and 285/70/18 Falken Wildpeak AT4W.
I'll have my real skids around the time I do my first oil change in a week or 2.
Does the 3.4L oil pan sit pretty close to the bottom of the crossmember?
I thought the 2.4L was pretty high up there, along with the 3.4L in my Sequoia, which I put a Fumoto valve on last weekend.
Maybe 2-3 inches above the bottom most plane of the crossmembers.
i have the 3.4 in my tundra, and yes..... 'wear' metals are notorious on these engines,
toyota says its machining swarf, whateverTF that means, i would do multiple early oil changes ( i did )
and pour through more oil while the drain plug is out to flush that s***e out of the pan, you WILL see extra crap come out.
Im not impressed with this but what do you do
New tires. Swapping tires completes the new 250. The stock Yokohama’s on the 1958 are severely lacking.
Toyo AT3 275/70R18
49lb per tire unmounted.
Nice I bought the same ones and size for my FE. Just waiting for it to actually arrive at dealer any day now? I have these same tires on my 88 FJ62 and love them. Great in all conditions and especially snow.
How did you feel they were 'lacking'?
Not aggressive enough for my taste, the size of the tire looks like it’s better suited for a crossover, paper thin sidewall, extremely limited options in the original tire size.
All subjective and varies per end user, but the stock tires I knew were getting replaced the second I saw them.
