Yep no reason that wouldn't work
I just got in from doing a few runs with the truck. I didn't hook up my OBDII data logger as there was no need to.
The truck dumps fuel at around 3700 RPMs and the AFRs drops to 10.0. It was quite obvious and I apologize for not realizing it when I did the change and am Glad that Scottryana has brought this to my attention.
The short explanation is that the ID of the bore is too small.
I'm going to call one of my machine shops locally and get his assistance in modifying the housing I have to correct this problem. I might have things worked out by Tuesday depending on both our schedules.
For those wanting to dyno their truck I really don't see the point now but after I work out a change it would be great seeing runs on several platforms.
The current run of housings will be halted tomorrow and then resumed once a fix is determined.
Interesting. Maybe the reason I've been so happy with the mod is I still have the Gen1 without the sleeve.
The smaller i.d. would maybe explain the power band moving so far down the rpm range, no? I did the super charger after the ltmaf, but the maf affected off the line performance for sure. If i read the dyno sheet right, you pick up a bunch right off idle, and lose it up top. I don't know if that's really a bad thing at the range i usually run in. I know on my bikes, chasing peak dyno numbers rarely translates to the most streetable power band.
Absolutely. Your not seeing the same dump and during open loop it's running an AFR of around 12.5 which is ideal for making power.
But the GenI required the sensing line removed to keep fuel trims in line during idle so the ID is actually a little too big.
I over compensated with the change and it effected the high end. Somewhere in the middle should be ideal. I just need to find it.
But too wide is relative no? I have the widened TB and will soon be installing the SC now that the motor is broken in. I have zero data to support. I just know more air equals mo powa
More air only means more powa if the fueling is correct. In the case of the GENI the fueling is correct and more powa is made. In the case of the GENII it's running rich and powa decreases even though the same air is consumed.
It sounds like Rick is going to devote the time to find and fix the problem so the next version will probably be Gen III, but Rick I still think there is more to it than just running rich. If you look at my dyno graph I start running rich at 2700 and it isn't until 4200 that the power really drastically falls off. Thanks for looking into this.
Just as another data point the LT MAF housing was run on a turbo'd truck at 9psi of boost and it was still seeing 10.X:1 AFR's at WOT. I would expect to see the same thing on a supercharged truck.
