VAF does not operate on the same principle at all, there is no correlation to MAF sensors. MAF = Mass Airflow Meter. AFM = Air Flow Meter (+ temp input + ecu calculations) = MAF calculated in the tables. The ecu doesn't *learn* anything with regard to MAF. There are just tables, meticulously designed and engineered to Bournulli's laws of flow thru a given size orifice. Just about every OEM manufacturer uses MAF to reflect quite accurate and actual engine airflow to a stock engine. The more accurately you do this, the better the EFI system will work.
By definition the wider you differentiate a 0-5v signal the more accurate the scaling will be of that input device. Add a margin of error for altitude and engine production tolerances, out goes the ecu tables.
Again, the graphs above confirm that, if you use them only as a MAF bore diameter change. In this case, the larger bore diameter is not well suited for the stock ecu programming, because it will never reach the ecu measure limit. The smaller bore diameter MAF has better resolution and uses the best scaling for the programmed limits of the engine air demand.
Welcome to EFI basics!
Scott J
94 FZJ80 Supercharged
thanks for the lecture, but nothing you said contradicts anything i said or addresses my actual point. what i said is that the 1993 landcruiser ecu is able to compensate for large voltage variations between VAF units at the same airflow.
your only clear point in this thread is that landtank's maf will likely send out a different voltage signal at a given airflow from stock. everyone knows that. the rest of what you are saying is speculation. you speculate that the voltage signal will be less accurate than stock by focussing on the housing, citing an extreme example of oversizing a MAF, and ignoring completely the different sensors. you speculate without any evidence that the ecu has some kind of arbitrary maximum permitted voltage input beyond which it will not attempt to map fuel, and you speculate that the differences in the voltage signals between stock and landtank will be so great that the ecu won't be able to keep up.
in other words, you have added nothing to the discussion other than a lot of verbage.
good luck.
and, for that matter, you are also wrong. the ecu clearly can learn about the signal from the VAF in the truck, because there is a large range of permissible variation in voltage signal between VAFs. it quite obviously must learn what voltage signal reflects what airflow condition in the VAF.
