Fuel Pressure Regulators and boost
There seems to be some misunderstanding of how Rising Rate Fuel Pressure Regulators work. Hopefully, this post will help some understand the relationship and the risks of capping a RRFPR during boost. For more on Fuel Pressure Differential see Posts 95-107 in this thread
The 1FEFZ uses a 29lb/hr (310cc/min) injector, rated at 3 bar (44psi - above manifold pressure). This means in a normally aspirated truck under idle vacuum, the 29lb/hr (310cc/min) injector runs at 2.1 Bar to maintain the 3Bar above manifold pressure (Fuel Injector Pressure Differential - per factory FSM and post 95 in this thread).
This also means that under boost with a 1:1 Rising Rate Fuel Pressure Regulator, at 10psi boost pressure, the rail pressure should be 54psi to maintain the 3 bar pressure differential. Let's look at what that means in terms of the 'new' injector flow rates.
At idle (2.1Bar) on a 1FZFE, a 29lb/hr (310cc) injector at 2.1 bar will now flow (sqrt{new pressure/old pressure} * old flow rate = new flow rate) 24.82lbs/hr (260ccmin). That's 15% less fuel than what it flows at 3bar.
Enter the turbo.... If you add 10 psi of boost to the manifold, with a
capped FPR, your rail pressure is 3Bar (44psi) but the manifold is .7Bar (10psi) above atmospheric.. So the Pressure Differential is 2.3Bar (33.7psi). So, using the same equation, a 29lb (310cc) injector at 3Bar (44psi) running 2.3Bar (33.7) will now flow 25.96lb/hr (273cc). 10.5% less fuel (lean) with no other changes.
Let's look at the affects of altitude, say 5000feet in Denver with 10psi of boost. Rail Pressure is still 3Bar, but the absolute atmospheric pressure due to altitude is less. So (.8598 x 14.66667) = 12.610 atmospheric = 1Bar *3 = 37.8psi. 37.8psi - 10psi boost pressure = 27.8/12.610 = 2.2PR. The new flow rate is now 25.3 lb/hr (265cc/min) . 15% less fuel (lean).
This indicates that the boosted trucks are at the highest risks with this mod, those boosted trucks at higher altitude, have more risk than those at sea level. However, without a voltage scale of the modified MAF, what's really happening is anyone's guess. With the FPR hooked up, at least you keep the injector flow rates where the software has them tabled for a given manifold pressure.
Summary: A Stock 29lb Injector at 29lbs/hr (310cc) @ 3Bar will flow
24.82lbs/hr (260cc/min) at idle (2.1Bar) - Manifold line connected
25.96lbs/hr (273cc/min) at 10psi boost (2.3Bar) - Manifold line disconnected
25.30lbs/hr (265cc/min) at 10psi boost in Denver (2.2Bar) - Manifold line disconnected
The ECU software sees all these conditions as 29lb/hr injectors installed, since the Fuel Injector Pressure Differential in the software is assumed to be 3Bar always. This means under boost, with the FPR capped, the fuel injectors flow less fuel = lean condition. To accept the theory proposed by Landtank, the installation of a 4Bar Rising Rate Fuel Pressure Regulator would be the 'proper' argument I 'think' he's trying to make. Without the voltage slope of the MAF, it's not relevant to make any argument..... This would also explain why a well respected Toyota Tech at a higher altitude might see higher NOx than one at sea level.
HTH
Scott J
94 FZJ80 Supercharged
