OK, first of all, none of what I'm about to report is conclusive. This is just observation from reading the scangauge and other factors could be at play here and I'm not 100% sure how accurate the scangauge is in the following readings.
But basically I ordered Landtank's MAF housing last week and just got it today. Awesome product! Fast shipping! I purchased a used sensor out of a 2003 Camry for about $40. Considering the numbers I produced tonight with my first runs, I really, really wish I would have made some recent runs with the old MAF.
Among other things, I tested the set up using the scangauges h.p. meter. I don't know how the scangauge determines h.p. but I assume after being imputed several factors like engine displacement, it uses it's numerous sensor readings to come up with a brake h.p. reading. Rather than compare the scangauge numbers to other data, its probably most useful to compare scangage to scangage on the vehicle in the same conditions. I couldn't really replicate conditions. My original readings were at 70 degree intake temp. The new readings with the Landtank MAP was at 40 degrees intake temp.
In going over my notes, when I made a number of h.p. test runs last year, the highest numbers I could achieve on the scangauge was 246 (brake) h.p. I was typically maxing out in the upper 230s. This is with a bone stock engine, and original MAF.
Tonight, after the MAF install, the highest reading I got was 306. Most runs showed in the very high 290s.
The only difference in the engine itself was the Landtank MAF.
Air temp was at least 30 degrees cooler, so we can probably attribute around 6% of that gain to the colder denser air. That leaves us with about a 15+% power gain that can't be accounted for, except for the Landtank MAF.
Seat of pants experience did seem to confirm a significant power increase at WOT and upper rpms. When pushing past legal speeds, even going uphill and loaded down to over 6500lbs, it just wanted to keep speeding up. Not what I remembered with the old set up.
But the numbers I was seeing almost seemed too significant, even taking the weather differences into consideration. I can't believe that an MAF would make that much difference. I really wish I had taking direct readings using the old MAF on the same night for a more direct comparision. I'm almost intriqued enough to put the old MAF back and run the numbers, then run home and put the new one on and do a direct face off.
So, has anyone else with a scangage experienced similiar results? Gains of more than 15%?
On a slightly seperate note, the 1FZ was produced long after 1997 and as it turns out later model 1FZs made more power. 221 h.p. and 285ft/lbs of torque to be exact. And this is not the VVTi models that made 240 h.p. These are just the run of the mill Aussie 78 series models. I know Toyota improved the intake system and made a few other tweeks, but I've been wondering if Toyota added the same type of sensor or something similiar in later 1FZs that really helped out this motor and now those of us with the Landtank MAF appear to be experiencing the same type of gains.
Anyway, more later......
