Nemo, sorry to hear about your problems.
Did you get aftermarket or OEM O2 sensors on the original truck. Many people on the board have had issues with aftermarket O2 sensors. You may want to consider that issue too. In that search you may note that typically when the O2 sensors are replaced with OEM units the truck's mileage downs a bit. The owner ends up annoyed that the truck's MPG drops by about 2 mpg after spending a bit of coin on the sensors...
From the original testing my older O2 sensors tended to cause the truck to run a bit leaner than Rick's truck. This was noted during dataloging. Rick had just changed his O2 sensors and my truck's O2 sensors were original.
Good luck.
Good luck.
