Gutted the cargo area plastic trim.
Removed the headliner speakers (recommendations?)
Removed the rear cargo shoulder belts
Installed a new sub. Which was a waste as I'm sure everyone would want a 10" back there, yes? If so ill design a new mount that's identical to the OE that accommodates a 10" sub. Ill work on that solution.
Removed the tailgate carpet pad and will inspect where mounting holes will be for the cutting board as I'm leaving the clip holes alone. Also I smacked it a few times and it rattles, so ill be replacing the foam around the rods and packing grease in the rod ends and clips.
Zuri our female pup was in there with me and then I had a thought about the rear glass. There no way to lock the slider in a position to prevent the dogs from poking their heads out or ever escaping (GSDs are co dependent) I was thinking about a way to lock the glass open. I think a hooked bracket to attach to the striker and the other to lock into the latch. 6-8" would be great. Then I thought about the Speski barrier and I had drawn up a window PALLs/MOLLE compatible barrier. If I adapted it to the 80 with a 4" slot across the middle then you could open the windows and your dogs can't get out and you can leave them open and not worry about theft. Just a thought.
Also those windows don't move without a lot of effort. Mr Gup says to clean the crap out of them. It's odd just how tight they are, ever the door glass is crazy tight. Also there's a 1" gap on both rear sides in the window channel seal, normal or shrinkage?
My girl tore into the carpets and they came out amazing. She also took all the plastic into the tub with Super Clean and and knocked them out.
Back to the door panels, mine are a taupe color, was this a year color or only for cloth guts? Anyone?
Also I removed the jack storage bracket in the quarter panel. Would there be a need for something else to mount in there, like a platform to mount a compressor or inverter to?
