For sure service the starter. Toyota Denso remain is top shelve. Denso reman a close second. Difference according to Denso Tech support. Toyota requires certain parts replaced. Denso, it's up to rebuilder. 98 starter, is very rebuildable, which is also good option. But the parts in remains (Toy Denso or Denso) other than contact and plunger can be extensive, so hard to compete with even DIY. At 315Km 23yr, it's very likely been done. You may find aftermarket in yours now, which then for sure get a reman.
I pulled my starter over the weekend PITA. I was planning on rebuilding myself, but have decided to just get a rebuilt. In calling around I understand there are different brands on the market. Edited: Rebuild myself. Which one is best for the money, considering the PITA job to replace would be...
forum.ih8mud.com
Fuel inject service is done by third party. Unless you've a sonic cleaner, test equipment and know how!.
Replace all gaskets, O-rings and seal you disturb.
It's a good time to replace all 4 water bypass joints front & rear gaskets.
Tips:
Clean top of engine concentrating on area where intake manifold and heads connect together. Be very careful not to get any dust, sand, crud, etc. into intake ports of heads. Check each port with flashlight and vacuum each speck of dust out, before assemble.
With any remanufactured starter. It is best to reseat contacts by the book (FSM), before installing starter.
