I painted mine with rust preventor and then smear the hex heads with marine grease. I also backed the bolts / valves out the three turns and applied grease on the threads. Just keep them clean whenever you have a chance to do so.
Is there a preferred product to grease and protect the KDSS valve?
My 200 spent it's entire lift in MS and is about the see the first ever road salt. Want to make sure it's protected as well as can be.
https://www.amazon.com/Lucas-Oil-10...&qid=1514339040&sr=8-3&keywords=marine+grease
Thanks!
No these aren't bad. These are great!This doesn't look too bad, does it?
I would give them a quick soak, then expect them to break free without too much fuss. Rest of the underside of the truck is in great shape.
This question has come up before I don't think we've ever determined it for sure! IIRC, I think a few hypothesis were:We busted ours open today, as part of the lift kit install on the new to me 2008. My son tells me they were stiff but he was able to get them open three turns without stripping. Will grease liberally with Bel Ray waterproof grease (cause that's what I have on hand) when I put it together.
What is the open connector for on the sheet metal cover over the valves?
Just a PSA (Public Service Announcement): With all the deicer they spray on the roads around here, I was slightly concerned about the KDSS system corroding, as well as other under vehicle components. Yesterday at about 10k mi on the LC, I crawled under the cruiser, wiped all the dirt and grease off the KDSS valve, checked for corrosion (there was none), and reapplied fresh grease. I'm happy to report that the every-other-week car wash undercarriage wash is doing its' job and everything looks great. I've seen other cars around here where the owners have ignored the effects of the deicer they use, and it's UGLY.Thanks for the tips. I crawled under my 600 Mi. LC, found the valve, hit it with some Emery Cloth (just to make sure it's fairly clean), then liberally slathered it with marine grease. Will repeat this every oil change. Hopefully, this preventative measure helps me side-step the ugliness shown in some of the pictures here.
Reviving this thread as I'm in the process of prepping my KDSS adjustment screws for servicing (break free, back out three turns, apply anti-seize to threads, retighten, etc.)
I was really lucky as my valve has very little rust and the screws are clean. I've been hitting the screws with Kroil (wonderful stuff BTW) and I cleaned up the area around the screws with a dental pick.
Here's my question as I didn't see it answered already:
When the adjustment screws are retightened, will they stop turning clockwise when they reach the zero / factory closed position? My fear is they will continue to turn into the cast iron housing past their original "set" position. My initial thought was to mark their current position with a dimple to ensure I retighten them to the right depth, but if they bottom out at the correct position, then this will not be necessary.
I hope the above question makes sense. I'm going to keep soaking the screws with Kroil (with tapping) for another week before attempting to loosen them.
