I installed the Maxxima LED headlights and ran into the same problem. The lows don't stay on when you switch to the high beams. I've tried different pin orientations but doesn't seem to make a difference. Anybody got any suggestions?
I'm installing Evo2 Low Beams and did the black/yellow wire swap. Using stock harness. Low beams only work when HB is ON. Anyone have this problem? Any suggestions?
'89 62
Check here.For some reason, my low beams will only work when I have the high beam engaged (both high and low will turn on when high beam is on, but low beam won’t when headlights are on).
Hopefully I explained that well enough - anyone have any ideas?
Check here.
Instructions for LED Headlight upgrade
Here are the instructions I used to get the JW Speaker LED lights to work in my 1990 62. I’m not a mechanic, elecrician or a very bright guy so if I can get it to work, anybody should be able to do so. It took me a while to do this but most of the time was compiling information which I have...forum.ih8mud.com
