Matt, if you aren't too far try some spray copper gasket sealer on your gasket. Another trick is to double up. gaskets its a bit hoakie but it works.
. Everything apart. Clip installed, Everything back together.
. That spot looks familiar. I think my wife and I considered having our wedding there.
Apply lube generously.
Our transmission is a lush and insists on stealing from the transfer case.
Super trick hose from @shipmag should help even things up.
If we can keep the 85-90 wt in the cases, might even clean down here too.
Got a used tire carrier hook we're trying to get on.
3 rusted bolts busted by someone long before us, and one body nut that we could thread tap.
The sheet metal behind behind the area is pretty wasted. We'll end up with 3 bolts, two will be through bolted with washers on the back.
Gotta hit up ACE for some longer M8s.
Trying to keep ticking away at the to-do list so we get out camping in it this summer.
View attachment 2663956View attachment 2663957View attachment 2663959
That’s brilliant.I got really tired of hearing my antenna bouncing off my gutter lip, so I glued a neodymium magnet to a piece of kydex with a hole drilled through it. The magnet attaches to the gutter lip and the antenna goes through the hole. It keeps the antenna from swinging around too much, but can easily pull alway if the antenna gets caught on something.
Still in the works:
-Mounting FJ60 seats in the front.
-Dizzy upgrade
-new u-joints
-new window seals
