@smokedpig Forgot to mention …be sure your motor is up to par without other issues…the Sniper EFI won’t cure other problems and may in fact exacerbate them.
Based on this:What year original Aisan? there's a date code stamped on it. If it's the '74 I would make every effort to make it work.
Oooh, that does look rough. Seems to have been last serviced by a knuckle-dragger with the wrong screwdriver and fittings from Ace hardware. And it's a vacuum-operated secondary.Based on this:
Carb Aisin Identification for Rebuild
Hello, I have a 82 FJ40 and I want to rebuild the carb, I dont know what exact model it is so I can order the kit. Attached are images and awaiting your feedback.forum.ih8mud.com
Looks to be May 27, 1976 (6 E 27). Still worth it?
I ordered a new mechanical fuel pump from City Racer today. Will report back once it is installed.A mechanical fuel pump rebuild is pretty easy to do. I think citiracer has a kit or SOR and not very expensive. A mechanical pump runs at the speed of the engine as it’s driven from the cam. Once rebuilt will last a long time.
A small (40) world it seems...I looked at the listing for this 40 in western mass far too many times! I'm glad you bought it and joined up with the MUD crew! Now I know what the rest of the story is for it!
Welcome
Thanks igotta40!From your photo it looks like your 1971 F motor has a 2F valve cover. And you’re running low on brake fluid. Congratulations on getting a 40. Mine the is also a 1974.
