Builds Introducing FZJ 80 "Dingo" (20 Viewers)
This is incredible! I hope I can find a write up on the proper way to prep the vehicle for Al's Liner, as I'm planning on doing this same thing. Before I'm ready to do that I'll be doing my wheels. How has the paint held up offroad?
I knew it had to be white or tan as a tribute to the guys I worked with overseas. I decided on tan. I researched on Mud and found several good threads. I liked ashooter's : https://forum.ih8mud.com/paint-body/231630-not-50-paint-job-but.html And after seeing Ardentyota and his LC: https://forum.ih8mud.com/80-series-tech/400405-lined-my-80-tan.html and Plutonius' : https://forum.ih8mud.com/80-series-tech/404567-lining-whole-rig-als.html I decided to use the Al's Bed Liner.
What, does EVERYBODY here know auto body but me?? :frown:
Sheesh...
Truck looks cool though. Great idea.
I'd love to drive across Afghanistan. Well, maybe when the shooting stops anyway. ;)
I actually considered a Trooper before I got the 80.
Both the wheels and the Al's liner are about the same as when applied almost 2 years ago! I would recommend both to anyone wanting a durable easy to care for finish. I have touched up my rims when scraped using a spray can, but other than that, nothing.
As to prep, Al's comes with good instructions and its own primer.
Cheers.
I read through the thread and may have missed this, but are the Center hub caps the stock ones or did you source some other ones? They seem to surround the lug nuts better than my stock caps. Nice job with the truck. Referring to the pic of your wheel after the black paint applied.
Not sure which picture you are referring to, but I have now discarded the caps and just painted the hubs.
Cheers
I'm curious to know how the Al's Liner is as far as cleaning. Is it tough to get clean again? Any residual dirt/scratches/marring in the finish that you can't get out? This seems to be the biggest word of caution when doing an entire vehicle.
After 3 years the Al's is doing well. The worst marks were from driving through a forest fire deadfall area. Lots of what I thought would be permanent scrapes and scratches. Nope, came right out. There are a couple other small dark marks that I have not bothered to scrub out, but probably could. I use a pressure washer and nylon scrub brush. For tough stains I have used scotchbrite pads. I have not had any issues with scratching or marring.
After another adventure I thought I'd update the thread with some new photos of Dingo. In October we traversed part of Nevada from the Utah border along the Pony Express trail. 250 hard miles in 3 days/nights. A lot of the trail hadn't been used for a long time, as evidenced by the tree growth across the trail and lack of identified road surface. Someone pointed out the trail was only designed for a skinny horse not a Land Cruiser.
Dingo was usually out front breaking trail. The brush wires and Al's Liner again saved the day and recovery involved scrubbing the tree marks off the sides.
Great build. I live in the southwest of Arizona and I am looking at some tall skinny km2 tires. How do they work in washes and sand areas. Again great build.
Thanks. I have had zero issues in the terrain of eastern California or anywhere in the Nevada deserts. The KM2s when aired down offer excellent traction. I drive in low range with center diff locked and have a rear Aussie Locker. If you are looking to drive on dunes, I would consider more of a flotation tire, but otherwise would endorse the tall skinny tires (255/85 or 235/85).
Here is a quote from an article from Expeditions West:
"As quoted from Sahara Overland, a Route and Planning Guide by Chris Scott (2004, ISBN: 1-873756-76-3):
'...Note that it's the diameter or height of the tyres that makes the difference in sand, and not, as many imagine the width... For the desert, you want tyres with a high aspect ratio of around 80 because this represents a taller sidewall so corresponds to added ground clearance when firm, and a longer contact area when deflated.'
" Traction in soft surfaces: It is a common misconception that airing down a tire for off-road traction only makes the tire contact patch wider. That is not the case. In fact, only 20% of the increased contact comes from the width. 80% of the increased contact patch comes from the tread patch becoming longer. A tall, narrow tire allows for a very long contact patch when aired down. That, coupled with the minimal frontal resistance (area), negates much of the downside to narrow tires in flotation situations. The taller tire allows for a long contact patch and still maintains good ground clearance."
Here is the complete white paper link: http://www.expeditionswest.com/research/white_papers/tire_selection_rev1.html
Cheers,
Greg
Excellent, thank you for replying so fast. I do not plan on dunning as the hourse power just is not in my favore. I am running a 15" wheel and was looking at the 33x10.5r15 km2. I love the look and the thought process and science makes sense to me.
Different subject. What locker did you go with in the rear?
I just discovered this thread, and man, we gotta know each other. We were in some of the same places at the same time, for sure. Great job on the ISAF-mobile, btw. I was inspired, as you were, by the Land Cruiser I drove (and occasionally rode in) in Afghanistan, and think they are brilliant.
I just bought an FZJ 80 in Phoenix and will be driving and fixing it up to basically match my Afghan ride. In fact, I'm driving to San Diego from Phoenix with my work partner, who I worked with in Afg around the end of this month. (26-29 Jan).
Here's my Afghan ride: Maybe you recognize it/me?
Here's my new ride:
I think I am going to shamelessly steal a bunch of your ideas, though my lovely bride insists on dark blue or red for a color.
My blog:
https://hotmilkforbreakfast.wordpress.com/2015/01/16/magic-carpet-ride-3/
Close, but not yours...best of luck with the build. Happy to help with whatever lessons learned I can provide. This forum has fantastic ideas and participants. We will definitely have to link up. As to your color choices, if you are contemplating bed liner, maybe look at Monstaliner they have a lot of great colors.
http://www.monstaliner.com/
Actually, I know who's ride that is. The snorkel and the windscreen bling give it away. That vehicle had a persistent and intermittent door locks failing "locked" issue if I recall correctly. Friggin' death trap, imo.
I helped pick those up from BAF when they first hit country.
Certainly you remember this chick? Possibly we "whiffed" each other, though. Lots of times I've met guys who were in exactly the same place at exactly the same time, and not only didn't meet, but often had diametrically different experiences/perceptions.
